Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 07-19-2013, 11:49 PM   #1
2SSRSinBama
Drives: 2010 2SS/RS Camaro CGM
L99 gears 3.45 or 3.70?
in the process of adding a circle-D 3200 stall, 18" Drag radials and E.T. streets and the car WILL see a 125 shot next spring... for the L99 guys, is 3.70s too much gear for the street? I know DRs will be must with a 3200 stall but I'm not wanting TOO much gear(as in prepped track on ET streets or I go up in smoke, lol) and I can get a set of 3.45s pretty cheap...
2010 Camaro SS L99... has a few mods
2SSRSinBama is offline   Reply With Quote
Old 07-20-2013, 02:33 AM   #2
Supercharged SS
Drives: 2010 Camaro
A 3.70 will put you into 5th gear by the end of the 1/4. Not to mention it'll be way to much on the launch. Go 3.45's.
Supercharged SS is offline   Reply With Quote
Old 07-20-2013, 07:24 AM   #3
LS7 427
10.11 @ 136.32
LS7 427's Avatar
Drives: Black & Yellow 2SS/RS LPE LS7 427
I had 3.70 gears and changed to 3.45 gears for exactly the reason Jamie mentioned above.
My Build Journal
Built, Tuned and Maintained By........
LS7 427 is offline   Reply With Quote
Old 07-20-2013, 07:38 AM   #4
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
What about for higher power levels? Or are 3.45s in general what work for an auto?
DarkCry956 is offline   Reply With Quote
Old 07-20-2013, 07:55 AM   #5
Motion427
Drives: 2010 2SS/RS Red Jewel L99
The last time that I was at the track,I crossed the line at about 5700RPM in 4th gear. mph was 118.
28" DR. 3.45 gears. torque converter flash at 2000RPM.Cammed car.
I now have a 3400RPM converter in it,hopefully will run it at the track again soon.
Motion427 is offline   Reply With Quote
Old 07-20-2013, 04:30 PM   #6
2SSRSinBama
3.45 it is... now anyone know about this company? or another source for 3.45s?
http://mudflaps.com/i-13176286-g2-ax...FUqk4AodmzkAsw
I'm going to check with Performance Torque Converters(PTC, huge name for torque converters here in the South and is local to me, like 10 miles from my house, lol) about getting a converter for a 6L80E through them, but if not, I can get a 11" built through Circle-D with a 3200 stall shipped to my door for around $550, Yank and TCI are ridiculously priced on their converters...
Old 07-20-2013, 04:35 PM   #7
Supercharged SS
Drives: 2010 Camaro
3.45's is what you want.
Old 07-20-2013, 04:39 PM   #8
Supercharged SS
Drives: 2010 Camaro
Get the GM 3.45's
Stay away from the PTC. It's a great converter... In a different car. We have one in the grand national. It's at PTC right now.
Go with the Circle D. Get use to camaro parts being overpriced. It's just how it is.
Old 07-20-2013, 06:25 PM   #9
Rockit_z28
www.1baddogracing.com
Rockit_z28's Avatar
Drives: 2010 IOM 2SS/RS Auto
I cross the line in 4th gear with 3.70s with no problem and ran a 1.50 60'. I do agree that a 3.45 to 3.50 gear is better on high horsepower applications and makes for easier tuning especially on the 6l.
2010 Camaro 2SS/RS Aqua Blue Metalllic (bolt-ons)
2020 Camaro 2SS/RS Satin Steel Metallic - Shock and Steel Edition 1 of 98 - A10 (bolt-ons)
2010 Camaro 2SS/RS IOM - 1,023 RWHP 813RWTQ (Previous Paxton Record Holder: 9.82@139)
Built and Tuned by Heintz Racing
Go: DSS 9", RPM Trans TH400, Carlyle Racing 15" Conversion, ECS Vortech YSI-B, Fore Fuel System, ID1700, Gall Racing 427 C.I LSX, Mast 285CC Heads, HR Custom Cam
Show: Custom Painted Stripes/Badges (Orange Pearl over White), Z/TA Spoiler, VFN Hood, Weld Wheels
http://www.HeintzRacing.com
http://www.youtube.com/user/1baddogracing
Rockit_z28 is offline   Reply With Quote
Old 07-20-2013, 06:36 PM   #10
Motion427
I can get 3.45's if you need a new set.Master install kits aswell.
Old 07-20-2013, 11:54 PM   #11
62nalide
62nalide's Avatar
Drives: 2013 SS
I would recommend a multi disk converter from Circle-D I had a PTC and was not happy a Circle-D was a way better one , the 6L80Es respond very well with multi disk a lil pricey but way worth it.
62nalide is offline   Reply With Quote
Old 07-21-2013, 03:40 PM   #12
2SSRSinBama
what about the Yank SS3200? and anyone have a part # on the GM 3.45s?
Old 07-21-2013, 04:46 PM   #13
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
If you get a triple disc Circle D converter, 3.70 will definitely not be too much gear with a stock height tire! You will be able to lock the converter which does change the equation. In a bolt on car this is the perfect gear.
However, once you add nitrous, your hp may throw you over the rpm limit. I would say it could be close but probably slightly run out of gear.
Really depends on which set up you want to optimize. Your NA bolt on set up, or your nitrous set up! If your goal is to have the fastest time with your nitrous then I would say 3.45's.
Fyi, I don't think Yank sells a triple disc either,
Camarojt is offline   Reply With Quote
Old 07-21-2013, 11:28 PM   #14
2SSRSinBama
the reason I want to go single disc is... this car is a daily driver(well not really, more like weekend warrior, lol... I do have another car for work)... I know a multi-disc is very beneficial, but I think the characteristics of a single disc will better fit what I want out of my car... its not really a cost issue so much as it is, harsh lockup vs. non-harsh lockup...
