05-05-2020, 04:10 PM | #1 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
2020 Camaro Traction Control Auto Off!
Now this shit is just getting dangerous. It was raining so I had my jacket on and while adjusting the temp controls I turned off the traction control. What moron decided that the location was a good idea?
Before you all say "learn how to drive" I am quite a capable drive but if I am not expecting it to be off that is just dangerous especially with these tires, this HP/TQ and rain. |
05-05-2020, 04:30 PM | #2 |
Drives: 2020 Camaro LT1 MM6, NPP Join Date: Feb 2020
Yeah, I inadvertently change drive modes while shifting my car. It's not the best location for the mode selector either.
05-05-2020, 05:10 PM | #3 |
Drives: 2019 Camaro SS M6 Join Date: Jan 2020
If you would've scanned your dashboard, you would have seen the icon showing you it was off. Driver error!
05-05-2020, 05:10 PM | #4 |
I do that also but not as much, and technically that can be even worse if you send it to Track Mode.
05-05-2020, 05:15 PM | #5 | |
Do not try to defend the lack of proper engineering on my driving skills. Hell, shifting through a corner I could turn it off with my jacket on. There is no need to be able to turn off TC or move through driving modes fast enough to warrant those buttons being in a bad engineered area. Last edited by FarmerFran; 05-05-2020 at 05:16 PM. Reason: nunya |
05-05-2020, 05:21 PM | #6 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
Changing the drive modes does not turn off traction control. You need to be in the PTM settings Sport 2 or Race mode for it to be off.
All 4 main drive modes Ice, Tour, Sport, and Track all retain stability and traction control. If you are in PTM Sport 1 and accidentally hit the selector toggle, then yeah, that would do it, but if you are in wet conditions I would think you would be only using the "Wet" sub setting, which is 3 clicks away from Sport 2 (which is the first setting that turns off traction control)
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
05-05-2020, 05:38 PM | #7 | |
No matter how you slice it, stupid ass location from a stupid ass engineer, who probably drives a Prius. |
05-05-2020, 05:43 PM | #8 |
Hey Fran: I wasn't insulting your driving skills! I just said it's your own fault it got shut off, not the car's fault.
05-05-2020, 05:54 PM | #9 |
Drives: like an old lady Join Date: Jun 2012
do you struggle at gas stations? is always putting 93 octane in your car a challenge because there are so many choices? when you muck up, is it the stations fault because they didn’t pump it for you? do you frequently pull up to the pump and get out to discover the fuel fill, in fact, is on the other side of the car (damn it not again)?
if so, you and fran can be friends
05-05-2020, 07:28 PM | #10 |
Drives: Camaro SS 1LE Join Date: Aug 2018
I agree with OP. Not the best location for that button— and others have stated the same thing.
05-05-2020, 07:46 PM | #11 |
Drives: 2017 SS A8 Hyper Blue/White Stripes Join Date: Jun 2010
I’ve never had issue with the location... I would bet a nice sub compact won’t have any sophisticated buttons in the console.. maybe that would be a safer vehicle for you.
PS: Glad your mistake wasn’t worse and you’re ok.
2017 Camaro 2SS Hyper Blue
2011 Camaro 2SS 2004 Corvette CE SOLD Last edited by Memphis SS; 05-05-2020 at 07:58 PM. |
05-05-2020, 08:10 PM | #12 | |
You should read your Owner's Manual for a more comprehensive understanding of all the modes and what each one does.
Current:
05-05-2020, 08:14 PM | #13 |
Drives: Fast if no one's looking Join Date: Aug 2019
Not sure what to say here other than there’s no problem with the ergonomics of the dashboard. I’ve never even come close to pressing a button anywhere on the car I didn’t intend to press.
05-05-2020, 09:29 PM | #14 |
