03-16-2018, 02:19 PM | #1 |
Drives: 2016 2SS Join Date: Jul 2016
New P1X dyno numbers 681/585rw.
Dyno numbers from today for the stock cam/long block P1X car. The runs were made in 5th gear. I added a Mighty Mouse catch can, LT4 injectors and highside pump. I also made some adjustments to the air filter. We were able to hit 180Kpa at 6,500 this time. We still ran out of fuel on pump at 11.8-12.0 afr at around 6,300 or 660rw so we had the bump it a little with meth. Looking at the graph now I guess I should have run it out to 6,800. I pulled out all the tuning tricks for fuel as well. It was plain and simple out of fuel.
Mark has decided to step it up so stay tuned. Maybe we will hunt down the all time P1X record.
03-16-2018, 02:57 PM | #2 |
Drives: 2016 2SS Camaro Join Date: Sep 2016
Nice though! I have a cam, long tubes, and pistons. On 93 (E10) we made 695rwhp with the Novi 1500
03-16-2018, 03:22 PM | #3 |
Daannggg, good work. We will see what it does in a couple weeks.
03-16-2018, 03:36 PM | #4 |
Drives: 2016 1SS D1SC Methfed Lowered Wrapd Join Date: Apr 2016
what tapped out Pray? Low side? Or does it need the fuel lobe from a cam to bridge the gap?
Did you use the Wild MM catch can? Any pics of it installed?
//2016 1SS M6 D1SC Upgraded IC 4.25 Pulley//
// Alky Control Meth Kit running 100% methanol // (purchased from JDP, installed by True Bliss Customs, tuned by NewEraPerformance in Augora Hills) // 3M/Gotch Design Sponsored Gloss Deep Space Colorshift Wrap // |
03-16-2018, 03:46 PM | #5 | |
We did get the mongo MM can. I will snap a pic when I get a minute. I had to adjust some stuff and reposition some stuff and make some stuff to make it work. I will get with David but I think two 90* turns would do the trick.
03-16-2018, 04:05 PM | #6 |
Drives: 1987 Buick Grand National Join Date: Mar 2016
Run meth wide open. Dual nozzle or single?
03-16-2018, 04:11 PM | #7 |
On the stock fuel system the single 10 nozzle was about wide open. We still had some room. The LT4 system was right there. At 12.2-3 AFR it held.
03-16-2018, 04:14 PM | #8 | |
Do you guys offer a drop in piston/rod combo? Is there even such a thing? How far do you think you can push just pistons on the stock rods?
03-16-2018, 04:23 PM | #9 |
Drives: 16' Camaro 2SS Join Date: Sep 2015
Cunningham offers a drop in rod/piston combo. I have it on my car, we still went ahead and removed the motor and did the "normal" machine work to it though.
@DeathWatchCamaro on Insta
993whp Magnuson 2.3R 9.5 @ 145, Magnuson 2300, Full Weight 2SS, 17’s (810whp) |
03-16-2018, 04:55 PM | #10 |
That's always a good plan. Did you have to re-balance? Did everything check out?
03-16-2018, 05:01 PM | #11 |
Drives: 2017 1SS A8 Nightfall Gray Join Date: Feb 2017
Think I read Cunninghams combo drops compression 1 point, if you find out its the high side pump I wonder how much more you would of gotten out of the lingenfelter bigbore over the lt4 if any. Are you still going to the track tomorrow?
03-16-2018, 05:03 PM | #12 | |
No, track is off for this car. Gonna dig in and get a bunch of stuff done.
03-16-2018, 05:09 PM | #13 |
Drives: 17 SS a8 Join Date: Feb 2010
I am now runing the Cunningham rods and pistons. I did nothing but a light hone. I weighed the stock vs forged set up and it was identical on my scale but my scale only went down to 4 gram increments. So far so good up 6000rpm and 5 psi. No smoke or funny noises.
Does that car have headers? Cats? Stock open npp?
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
03-16-2018, 05:15 PM | #14 |
We had it all balanced just because I wanted to be absolutely sure and my shop wasn't going to charge me anything for it. They weighed out perfectly to stock so I am sure it would have been fine. I forgot they do drop them a full compression point but we wanted that anyways since ours will be a maxed out all in build that will also run on pump gas on occasion.
