Old 06-10-2022, 08:56 PM   #29
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by shinysun View Post
Congratulations!
Thanks! Appreciate your help sorting that out.
Now we make another run at 1K WHP.
Old 06-11-2022, 06:54 PM   #30
Joshinator99
Had a chance to play around with this some more today. Around town, turning the dial all the way down nets 2 psi, which would be great if you got caught in less than optimal traction conditions. Mid point on the dial nets 8 psi (in my case) which is plenty for 98% of street use. Full turn up on the dial gives you full boost (whatever your pulley combo is capable of), or 15.9 psi in my case. Probably best saved for the racetrack. But having all this adjustability with no pulley changes is great!
Old 06-11-2022, 10:36 PM   #31
James Montigny
That guy
James Montigny's Avatar
Boost on demand ... I like it.
James Montigny
2017 Camaro 2SS A8 - Krypton Green
Magnuson 2650, TSP Head/Cam, DSX Low Side, Flex Fuel, LT4 HPFP, 103mm TB, Big Gulp.
James Montigny is offline   Reply With Quote
Old 06-12-2022, 08:13 AM   #32
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
Awesome, I’m not at the high power levels like Josh. I’ve been hesitant to go that high due to reasons mentioned. This product may change my mind if I can dial it back. Very cool.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 06-12-2022, 08:17 PM   #33
shinysun
Drives: 2016 Camaro SS
If you put a switch for the full boost(I don't remember the color of the wire from the controller of SB, u can check it with ur manual), it is act like Nitro it is quite fun and scary.
or just dial all the way up during WOT.
shinysun is offline   Reply With Quote
Old 06-12-2022, 08:40 PM   #34
Joshinator99
At some point I’ll probably do a Holley Dominator ECU and that would let me interface with the Smoothboost to control boost by gear, plus an automatic boost dump if I run lean for any reason. I’m liking the possibilities with this boost controller.
Old 04-13-2023, 08:42 PM   #35
Joshinator99
So, a 2023 update: the Smoothboost is awesome and definitely needed to make the jump from my Whipple 2.9 to my new Whipple 3.0 blower. But the bracket and linkage are completely different on the new blower. So I sent Levon @ Smoothboost a pic of the new bypass setup and he promised to send me a different bracket to try since he has not seen the new 3.0 yet.
Old 04-13-2023, 08:49 PM   #36
Joshinator99
So the new bracket arrived and Levin thinks that if I just pull out the linkage “extension” piece that it could work. Close, but no cigar. I probably could have chanced it but didn’t want to guess. We really needed an extension piece, but one that was only 1/2” long! So my brother took my wife’s jewelry saw (she’s a silversmith) and carefully cut down the extension. He then brought it to a machine shop nearby that specializes in precision work. They drilled the piece lengthwise and then tapped it all the way through. After fiddling with the adjustment screws and testing out the actuator (both retracted and fully extended…very important or you’ll burn out the actuator), I think we’ve got it right! And I sent my results to Levon in hopes that future Whipple 3.0 buyers will be able to buy the Smoothboost without all the custom work that I always end up getting stuck with…
Old 04-13-2023, 09:00 PM   #37
JSH
JSH's Avatar
Drives: '20 ZLE
Justin uses it.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
Old 04-14-2023, 09:34 PM   #38
shinysun
I cut the original bypass bracket and did some custom works.
Old 04-15-2023, 07:17 AM   #39
Joshinator99
Attachment 1125113
Your swivel piece at the end is pretty far out on the threaded portion… I feel like you’re asking for trouble on that…! Adding the 1/2” solid extension piece eliminates that issue.
Old 04-16-2023, 01:55 PM   #40
Nmolina9239
Nmolina9239's Avatar
Drives: 2018 2SS
Josh, just like you told me would happen I’m in the same boat lol. Is the extension you cut part of the one you received for your 2.9 kit? Looks like I’ll be taking the same route as you. Going to message Levon and see if he can sent me the extension and do the same as you. Itching to get this build done. Just got my intake runners back from Katech to add the port injection.
2018 Camaro, Whipple Charged, RotoFab Big Gulp, Katech 103mm, LT4 Fueling w/ JMS BAP, GPI Drop in Rods and Pistons, Custom Cam, Ported Heads, Kooks LTHs w/ Green Cats and Mid Pipes, Corsa Extreme Mufflers, DSS Driveshaft & CV Shafts, Might Mouse Catch Can, Circle D T.C. #Team GPI
Nmolina9239 is offline   Reply With Quote
Old 04-16-2023, 03:55 PM   #41
Joshinator99
Yes, we took the big extension that came with the Smoothboost originally for the 2.9 and cut it down to 1/2” long (it’s probably 1.5”-2.0” long uncut). The end we cut off was mostly drilled through so the shop cleaned that up and then tapped it all the way through. You need to do that since both ends are being screwed into obviously.
As I touched on before, you need to make sure you have full extension of the actuator and that full extension is 100% closed on the bypass… if the actuator cannot reach full extension you’ll burn out the actuator. And you don’t want any binding either.
Hope that helps!
Old 04-16-2023, 07:02 PM   #42
toohighpsi
Drives: 2015 C7 Z06 M7
I checked the Smoothboost website, their bypass just uses a PWM output to control boost. If we can dig up the PID address for gear position on the GM CAN bus, it shouldn't be too tough to tie gear position into desired boost with the Reflex+ boost control - just thinking out loud here.
Mike
www.toohighpsi.com
2015 Corvette Z06 M7
2021 Porsche GT4 M6
2023 Corvette Z51
