Vararam
Old 09-14-2018, 07:34 AM   #1
Fatal Ty
Drives: 1992 LS3 Typhoon
Coil Pack Relocation Question
It may be a dumb question but I’ll ask anyway. I want to make the engine bay as clean as possible and the coils are an eye sore. My question is - how far can the coils packs move w/o affecting spark/performance on a high HP build? I know I will need extensions and plug wires but can I move them 2’, 3’, 6’, etc?
Fatal Ty is offline   Reply With Quote
Old 09-14-2018, 09:25 AM   #2
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Not a dumb question at all, I have wondered the same thing. My guess would be that moving them 3 to 4 feet away would have little impact on performance because the signal from the coil moves so fast through the wire it would not effect timing. Resistance in high performance wires is very low so the voltage drop would also be low and not interfere. Moving them to the trunk, well thats another story LOL.
zz430camaro is offline   Reply With Quote
Old 09-14-2018, 07:22 PM   #3
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
I have moved mine. As long as you use quality wires you won't have a problem. I bought bulk Taylor wires, boots and terminals from Summit and made my own. Just make sure you have a set of crimpers that are designed for spark plug terminals. My wires are about 4ft. long.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 09-14-2018, 07:43 PM   #4
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
I mounted mine on the frame rails right in front of the radiator. Bought a universal wire kit and custom made the wires to length... no issues here
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 09-14-2018, 10:34 PM   #5
Fatal Ty
Thank you for the info! You can quickly eat up a lot of length going around things. I’ll try to keep 3’ as my max length.
Old 09-15-2018, 05:56 AM   #6
Smokin19
Drives: 19' ZL1 A10, w/pdr
Can you see mine? If you look real close, you will see the wires going into the inner fender wells. Work done by Vengeance Racing.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, AWE Touring, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
Smokin19 is offline   Reply With Quote
Old 09-15-2018, 10:27 AM   #7
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
The ohms per foot loss can be seen in tests conducted by granatelli I use their zero ohms. also many varied set ups for cleaning up the engine bay in the sticky thread from the Moreno motorsports old post up top of the engine section page.
christianchevell is offline   Reply With Quote
Old 09-15-2018, 02:42 PM   #8
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '11 2SS/RS IBM/BLK M6
Remember when your Car was in the Shop.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly
SSBUSDRVR is offline   Reply With Quote
Old 09-15-2018, 02:55 PM   #9
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
Agreed with all post above. As long as you use a good wire kit you’ll be fine. I’m sure you could get 5’ before you run into issues but would try to stay within 2-4’ just to be sure. I moved mine on the frame rails 3 years ago and never have had any issues.
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 09-15-2018, 02:58 PM   #10
Jayjellyfish212
Drives: 2014 1LE
Old 09-15-2018, 04:11 PM   #11
Fatal Ty
Thanks everyone! Cars look great, never liked the coil packs on the valve covers.
Old 09-20-2018, 05:10 PM   #12
1FAST SS
1FAST SS's Avatar
Drives: 2011 Camaro SS
Originally Posted by Jayjellyfish212 View Post
Man, your engine bay is a work of art. Great job.
2011 Camaro SS Synergy Green
CAI Cold Air Induction, ADM Race Scoop, Apex Washer Bottle Kit, Vengeance Racing Kaotic Cam, DOD/VVT delete and LS3 conversion, American Racing LT Headers, American Racing Headers Off Road pipes, Borla S-Type Catback, FTI Billet Triple Disk 3600 rpm Torque Converter, DSS Aluminium Drive Shaft, AAC Plasma DRL's, Showstopper LED Sidemarkers,Carbon FIber Bow Ties, 35% Window Tint, Llyod's Floor Mats, JBL MS-8 Sound Processor, 2 Alpine PDX-1.600, Alpine PDX-4.100, JL Audio C5-650, JL Audio C5-650x, Alpine T10 Type R Shallow Mount, Stinger Dry Cell Battery
1FAST SS is offline   Reply With Quote
