06-07-2015, 04:38 PM | #1 |
Drives: 2011 1Lt Camaro Join Date: Jun 2015
No heat in 2011 Camaro 1 Lt
What's up everyone I have been struggling for the last couple of weeks trying figure out why I have no heat. My ac blows extremely cold however my heat is basically at room temperature. I have seen alot of post but they are from 2010 and 2011. Has anyone had this issue and sucessfully fixed it ?
06-07-2015, 06:14 PM | #2 |
Drives: 2015 Camaro 1SS/1LE Join Date: May 2015
Is the snow flake button illuminated?
Doug
USAF Vet 1999-2007 2015 Camaro 1SS/1LE LS3 - Black (Current) 2015 Camaro 2SS/RS LS3 - Summit White (Traded) 2016 Harley-Davidson Road Glide Special - Cosmic Blue Pearl |
06-07-2015, 06:23 PM | #3 |
376 cubic inches of fun
I haven't had this problem on a Camaro, but on other cars.
First place to check is coolant level. Low coolant=no heat. |
06-07-2015, 08:27 PM | #4 |
Check your coolant level first. Will your car come up to normal operating temp? If not, or if it takes a long time, I'd suspect a faulty thermostat. If all that is good, I'd get hold of a good scanner that will communicate with the HVAC module and see if there are any codes in the HVAC module. A faulty temp door and/or temp door actuator will also cause this problem. Your going to have to go to an independent or a dealer if you need the scanner. AZ, Advance and the others most likely won't be able to help you.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
06-07-2015, 08:56 PM | #5 |
No the coolant level is fine. And the snowflake isn't on.
