10-14-2023, 05:06 PM | #43 | |
Below is what mine looks like (no, I didn't top off the coolant just for this post, it's the same photo I posted in the "what have done to your 6th gen Camaro today" thread weeks ago).
10-14-2023, 05:09 PM | #44 |
Okay, I can fill it to the top. I just filled it to the full cold line.
RUXIFEY Smoked LED Side Marker Lights / Black SS emblem on rear bumper / Blue SS vinyl overlay on front bumper emblem / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint RE Audio RFX10D4 10" Sub / Hand-made sub enclosure / Hifonics Zeus ZRX1200.1D amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
11-15-2023, 10:13 AM | #45 |
I finally decided to change my spark plug wires while the car is down over the winter and thought I would show for those who do not know why our coolant levels drop overtime. If you notice in the picture, there are two holes that act as a breather/preventative overfill on the tank.
11-23-2023, 12:09 PM | #46 |
Drives: 2018 Hyper Blue Metallic SS 1le Join Date: Oct 2023
so I'm new to Camaros, had Mustangs, and a Challenger few years ago, glad I stumbled across this thread. My level would change quite a bit, but always seemed to be low, so after seeing this thread, I added some Dex Cool to the small service port, added to the middle line, sure enough, the top reservoir is to the top now...
11-23-2023, 01:26 PM | #47 | |
Thanks in advance.
New Mods - GPI drop ins, Kooks 2", LT4 fueling, Cam, Circle D Converter, 3.5 pulley & dual nozzle meth. Last edited by grampa_ss; 11-23-2023 at 08:17 PM. |
11-25-2023, 07:39 AM | #48 |
As long as you don’t let lower tank get overly low the air in upper tank will work its way out, having some air in upper tank is not a bad thing. If you look on photo, the fill cold line is down a bit from the top
11-25-2023, 10:11 AM | #49 |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
Good eye for detail - I hadn't noticed that marking before! However, the owner's manual specifies something slightly different for the final result, calling for the top tank to be filled "to the bottom of the fill neck." Not that big a difference from that "cold full" line, perhaps, but I figured it was worth mentioning what the owner's manual calls for.
11-25-2023, 10:12 AM | #50 |
Thank you. I was hoping that was the case.
11-25-2023, 10:20 AM | #51 |
I filled to the bottom of the neck. The fluid in the neck was higher than the air bubble section. So I stuck my finger down the neck to try and reach the bubble and found that I couldn't. There are separate chambers or sections in that top tank.
