Roto-Fab
Old 07-01-2017, 03:55 PM   #1
intensifi
Drives: '12 2LT Convertible
ZL1 front end air diffuser part numbers?
Hello,
I just installed a ZL1 front end courtesy of Gen5DIY.
I am looking for the part numbers for all items required to install what I believe are called "Air Diffusers" under the new front end.
These are strips of plastic about two inches tall that are in front of each front tire. Before conversion the original similar piece was a single strip across the entire front of the car.
The new front end has 4 square holes on each side which I believe are there to accept mounting nuts for the diffusers.
So what I believe I am looking for is the diffuser (L & R), the nut and the screw/bolt part numbers.
I tried to view the diagrams on gmpartsdirect.com but was unsuccessful.
My car is a '12.
Thanks in advance!
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 07-01-2017, 06:16 PM   #2
Cyber10
Cyber10's Avatar
Drives: 2010 Camaro 2SS/RS
Do you mean the brake ducts? I know those come in 4 pieces, 2 left and 2 right.
491 hp/438 tq
LS3 Conversion | Comp Cam Custom Grind | Mast Heads | Comp Cam Push Rods | LS7 Timing Chain | 180 Thermostat | Ported Intake | Ported TB | SLP UDP | K & N CAI | Custom 3800 Stall Converter | Aluminum 1 Piece Driveshaft | Kooks 1 7/8" LTH | High Flow Cats | ARH 3" Exhaust | ARH Mufflers | Eibach Lowering Springs | BMR Floor Brace Subframe Connectors with Tunnel Brace | BMR Moly Lower Rear Control Arms | Oracle LED Halo Kit
Cyber10 is offline   Reply With Quote
Old 07-01-2017, 08:34 PM   #3
intensifi
No.
The diffusers are under the car and mounted on the front end in front of each tire.
Old 07-01-2017, 11:24 PM   #4
Cyber10
Cyber10's Avatar
Actually I know what you're talking about now, they're the air deflectors that sit underneath the car in front of the wheels. p/n 22757643 and screws are most likely p/n 11570637. Pretty sure that p/n fits both left and right.
491 hp/438 tq
Old 07-02-2017, 11:26 PM   #5
intensifi
Thanks
Old 07-14-2017, 12:21 AM   #6
intensifi
parts arrived today.
It turns out you have to have the ZL1 wheel liners to mount them.
Maureen - I need wheel liners!
Old 07-14-2017, 12:57 PM   #7
Cyber10
Cyber10's Avatar
If I remember right the wheel liners are pretty cheap. Might as well add the brake ducts while you're at it
491 hp/438 tq
