Old 11-24-2021, 10:02 AM   #1
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
CORRECT DTC 70 pad to run with ZL1 1LE brakes
I have seen couple of threads about this but I decided to call the HAWK PADS guys to verify the correct information because I was basically using a PAD that will work but was NOT the optimal size.
I have ZL1 1LE brakes on my 2019 SS for TRACK DAYS, I have been using DTC-70 HAWK PADs , part number HB694U.605. I might add that I found these pads to be INCREDIBLE and quite an upgrade from the admittedly VERY GOOD Brembo stock Pads.
My rotor size is 15.35 inches which is important to remember because not all BREMBO setups run this size rotor. SS rotor is smaller for example.
Anyhow, the HAWK tech guy recommended that I run HB631U.622 because that PAD will cover almost the entire rotor. It comes CLOSER to the center hub and also goes out further to the outside edge of the rotor.
I will take PICS of BOTH pads and post back up HERE, once the 631 pads come in so you can observe the pad size difference.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 11-24-2021, 10:25 AM   #2
khcoaching
khcoaching's Avatar
Drives: 2021 1SS 1LE
^^ Awesome!
khcoaching is offline   Reply With Quote
Old 11-25-2021, 09:36 AM   #3
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Drives: /\yes, this is me/\
I watched a couple videos that reviewed these and the gyrodiscs and saw that exact difference of the actual area coverage difference. Pretty significant. Not many of the aftermarket pads have as large of a surface area.
TLSTWIN is offline   Reply With Quote
Old 11-25-2021, 03:37 PM   #4
GunMetalGrey
GunMetalGrey's Avatar
Drives: Track prepped 2018 Camaro ZL1 (a10)
Yeah these pads really bite, a semi professional racecar driver took my car around the track and exclaimed that the car has demon brakes like a racecar
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 11-27-2021, 07:00 PM   #5
sr71bb
sr71bb's Avatar
Well I guess we all get a case of the dumbass now and then. It appears by looking at the NEW HB631U.622 psds I just got in that apparently I was running those all along and NOT the HB694U.605 pads like I had thought (LOL). I guess I should have known better because AMP were the ones that ordered the PRIOR set for me.
I might add these DTC70 pads held up REALLY well. EVERY time I went to the track I changed from the stock BREMBO pads over to the DTC70 front and DTC 60 rear pads and then BACK to the stock pads after track day was done.
I marked ALL the pads so that I put them back on EXACTLY the same position each time I switched over. I DID NOT prepare the rotor in between the pad switchovers either. The DTC 60's are still good after roughly 12 full track days but the DTC70's were done.
I had Adam Poland at DOGHOUSE performance run my car with the DTC70 setup and he felt the brakes were unbelievebly good especially for a 3700 pound car. Adam is a national championship winning driver a couple of times over so thats a pretty strong endorsement.
Retired Cars BELOW:
Old 12-17-2021, 11:10 AM   #6
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
how did you like the dtc70 and did you ever run the dtc60 ?
Old 12-18-2021, 04:31 AM   #7
Zl1+911
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10
I have not been able to find a correct size ZLE dtc 60 front. Op - Have you found one?
Zl1+911 is offline   Reply With Quote
Old 12-18-2021, 08:11 AM   #8
sr71bb
sr71bb's Avatar
OK I dont run DTC60's on the front but the part number is the same BUT you need to specify that you want the DTC60 compound and NOT the DTC70 compound.
HB631U.622 DTC 60
The pad is 7.47 inches LONG and 3.74 inches WIDE with .622 thickness
The DTC 70's have MORE initial BITE than the DTC 60's and thats why I run them. I DO RUN DTC 60's as I mentioned on the REAR
Retired Cars BELOW:
Old 12-18-2021, 06:54 PM   #9
Zl1+911
Thanks
Old 12-18-2021, 10:12 PM   #10
sr71bb
sr71bb's Avatar
Thanks
deleted post
Retired Cars BELOW:
Old 12-20-2021, 10:46 AM   #11
kropscamaro16
aww so 70 front/60 rear but you have zl1 1le brakes not ss 1le?
Old 12-20-2021, 11:07 AM   #12
sr71bb
sr71bb's Avatar
brake upgrade
YES we upgraded to ZL1 1LE brakes FRONT and REAR which means of course I have 15.35 inch front rotors. With the DTC pads and slicks, the brakes will absolutely stand you on your head. Also upgraded to stainless steel brake lines. I was told by a professional race car driver that drove my car that the brakes were as good as he had on his race cars so that's a good enough endorsement for me LOL.
Retired Cars BELOW:
Old 12-20-2021, 11:36 AM   #13
kropscamaro16
haha nice i have the ss1le setup on my ss and stock rotors goodridge lines and dtc60 pads but not a fan of them so far so looking for different options
Old 01-14-2022, 11:07 PM   #14
tomster
RedLine
tomster's Avatar
Drives: 2022 ZL1 1LE
Been running HB631U.622 for years and I consistently get 2-3 track days... (Just looked up my Amazon history and I've been through 6 sets of fronts and 4 rears) by far the best track pad for these cars but no idea how you would be getting 12 days out of them...
2018 GMC 2500 "Blue" (Sold)
2018 ZL1 1LE Hyper Blue" (Sold)
2018 CTS-V "Black" (Sold)
2022 GMC 2500 "Blue"
2022 ZL1 1LE 6spd "Rapid Blue"
2023 ZL1 1LE Auto Rapid Blue (ordered)
tomster is offline   Reply With Quote
