03-12-2014, 06:53 PM | #1 |
Drives: Supercharged 2013 2SS/RS Join Date: Sep 2013
Loss of HP?
I know there are probably threads on this, but i couldn't find them. I deleted the muffler on my car and a mechanic told me that in the process i probably lost 20 horsepower. I thought the cats, and resonator would keep enough. Anyways, I'm not an engine specialist or very mechanical savvy, did i make a good or bad decision? and did i actually lose hp? He also said that putting it on the dyno before and after will show that i actually did, but i haven't/didn't do so.
03-12-2014, 07:04 PM | #2 |
Drives: 2000 Camaro SS Join Date: Feb 2010
The only thing you list was about 35lbs of weight.
03-12-2014, 10:41 PM | #3 |
Muffler delete you will not loose HP. If you cut out the H-Pipe on LS3 or resonator on L99 and do not X-Pipe it you will loose HP and TRQ due to loss of cylinder scavenging.
03-12-2014, 10:45 PM | #4 | |
Drives: 2011 SS Join Date: Jan 2014
03-12-2014, 10:53 PM | #5 |
WHAT RED LIGHT?!
Drives: 2011 Black Camaro 2SS/RS M6 Join Date: Apr 2011
Mechanic is wrong...stock muffler basically goes straight through with a small J pipe for drone. All you really did was increase volume/drone and lose lbs, but no loss of power.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
03-12-2014, 10:53 PM | #6 | |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
03-13-2014, 01:42 AM | #7 |
ask that mechanic if he thinks you will get that 20hp back with a tb spacer.
03-13-2014, 10:11 AM | #8 | |
Drives: 2010 Camaro SS Join Date: Jan 2014
03-13-2014, 10:17 AM | #9 |
My car has a muffler delete (until today, that is) and I didn't notice ANY drop in power when I had it done. I never it properly checked, but from what I could tell from the "seat-of-my-pants" it was just fine. Still broke the tires loose if I wasn't paying attention or any little mix-up like it was nothing.
03-13-2014, 10:56 AM | #10 |
Lifestyle = Deathstyle
Certain cars this could be an issue...you are fine as stated previously in the above comments.
11 2SS/RS
03-13-2014, 10:59 AM | #11 |
www.jannettyracing.com
03-13-2014, 08:25 PM | #12 |
Lake Erie Monster
Drives: 02 Hyundai Santa Fe and 13 300 Join Date: Aug 2012
Ha!
Everything I say is to be taken as an opinion and not fact so don't get upset over words that spill out of my head.
GO CAVS! |
03-13-2014, 09:56 PM | #13 |
Con10der
Drives: 2010 2SS/RS M6 IOM Rally Stripes Join Date: Aug 2012
Your Mechanic probably makes a living selling Muffler Bearings too!
2010 2SS/RS M6 IOM w/Rally Stripes. BLK CAI w/ADM,WW Relo,2" Kooks,3" Cats-Mids,Vmax Ported TB,Muff Del,Janetty SCT Tuned,Drill/Slot BLK Hawk rotors,Red Grani Brake Lines,Motul 600,IDEAL Master w/res,Moroso CC,Accel Silver Tips w/TVolt 10.4mm,MGW shift w/Retro hand/ball,ABL Kit,Billet/IOM pedals, ZL1 split,Lloyds SS mats,PC Droid4/MAXX docking,HW Solo2.
Pend Install: Launch/Shift Light,BMR Susp/1" Drop/Sways/Track Pack,GM 3.9. Future: Janetty Pumpkin w/PosiTrac,1400HP axl,CF DS,Tick Stage 2 Trans,3 Disc Clutch,4"quad tip,center exit AB w/diff... |
03-14-2014, 09:30 AM | #14 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
Guys an idiot don't go back to him.
plasti dip is not a mod.......and a cold air intake doesn't make you fast!
