TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 05-01-2015, 09:54 PM   #1
eblanchette
eblanchette's Avatar
Drives: 1LE
Brake master cylinder leak ?
Hi, I am having some issues with a brake cap leaking on a 2014 1LE 2ss Camaro with 1K miles.
The dealership replaced the cap with no result, it is still leaking a bit; I had them order another fluid reservoir that they should install soon.
Now, I noticed something else and I am wondering how to test if the leak is from the master cylinder itself, OR if the leak originates from something else.
Any suggestions are appreciated!
Thanks!
Here are some good pictures :
eblanchette is offline   Reply With Quote
Old 05-01-2015, 10:41 PM   #2
Candr3535
Candr3535's Avatar
Drives: 2013 ZL1 Triple Black Vert M6 #5591
I'd be making them repaint that shit wth.
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice..
Candr3535 is offline   Reply With Quote
Old 05-01-2015, 10:46 PM   #3
eblanchette
Drives: 1LE
Of course!
but what good is a repaint or new part if the master cylinder leaks, which is what I'm trying to diagnose.
Old 05-02-2015, 11:21 AM   #4
29er
29er's Avatar
Drives: 14 1LE Garage King
cannot say if,it's the seal between the booster and brake master cylinder.it's a seap and not a leak if it was leaking the level would be low and the brake pedal would be much smoother than when it was new.and paint would have come off&oil on the floor too!
that seapage came only from time.like you mentionned it was the cap that's causing the leak.
so just check around, where that oil could of go... runs on the edge of the reservoir, it goes under and it follow the master from underneath until it reaches the booster ... until it barely drips on the firewall or inner fender...
make that warrenty work.
29er is offline   Reply With Quote
