08-07-2013, 06:38 PM | #1 |
YOU.ONLY.LIVE.ONCE
Drives: Camaro 2LT/RS 2013 Join Date: Aug 2012
Remnants of plastic dip
Hi everyone,
Recently I paid someone to plastic dip my rims but to my dismay theres over spray or excess plastic dip on the freaking inner barrel of the rims and its very hard to removed them. Is there any way to easily peel them off or remove them?Thanks
08-07-2013, 06:44 PM | #2 |
Drives: 2017 A10 ZL1 Join Date: Apr 2013
you should be able to take a cloth and rub it off
08-07-2013, 06:47 PM | #3 |
Drives: 2011 Chevy Camaro Join Date: Sep 2010
Usually the entire rim is plastidiped. Clay is the best and easiest way to remove overspray
08-07-2013, 06:50 PM | #4 |
Drives: 2013 Camaro Join Date: Jul 2013
I missed around with plastidip today for my emblem.......Once it drys it should easily come off with a good rub.....Or use some basic cleaning spray to get the light over spray off.......Its kinda hard to peel off a lightly sprayed area...
08-07-2013, 07:04 PM | #5 |
Drives: 2013 2ls Join Date: Aug 2013
I used Isopropyl alcohol (rubbing alcohol) with a rag to wipe off overspray. Comes off with ease.
08-07-2013, 07:09 PM | #6 |
YOU.ONLY.LIVE.ONCE
This is how it looks like after washing the car.
08-07-2013, 07:50 PM | #7 |
Drives: 2014 Z51 Corvette Join Date: Dec 2008
Try WD-40
08-07-2013, 10:36 PM | #8 |
Smoked by a GIRL
Lacquer thinner and a rag works great on the thin over spray. That's why when you use plastidip its important to use thick layers bc the thin layers are hard to remove.
2014 2SS/RS Summit White w/ IOM interior "Powder 2.0"
08-07-2013, 11:41 PM | #9 | |
YOU.ONLY.LIVE.ONCE
Thanks everyone for the recommendation.
08-08-2013, 09:25 AM | #10 |
Smoked by a GIRL
He shouldve prepped better. Tape and newspaper is your friend, lol. I've used lacquer thinner to get the over spray off the garage floor before and it works better then rubbing alcohol.
08-08-2013, 10:25 AM | #11 |
Retired from Car mfrs....
Mineral spirits melts PD.....
