09-22-2015, 12:48 AM | #1 |
Drives: 2013 Camaro 2SS RS Convt. Join Date: Mar 2011
Technostalgia TL's power wire question installed in a Convertible
I'm in the process of installing a set of Technostalgia tail lights in my Vert.
I'm to the point of running the power wire to the batt. do I need to drill an access hole from the tail light pocket into the trunk to run the power wire to the batt.? Or is there a better way? I've read that some people have run the wire up to the fuse box up front or to the fuse box in the trunk. Any help would be greatly appreciated!
2013 Nickey Stage II Camaro SS Convertible #10.Black w/ Red leather interior. No Weeds Elec. Diverters, CNC ported heads, custom grind cam, upgraded fuel injectors, ZL-1 fuel pump, V-Max ported TB, Red Magnuson Super Charger with rear cog drive, upgraded rear axles good for 1400Hp, 3:45 gears, Tremec 6 spd., Pedders adj. coil overs, Phadt ZL-spec swaybars, 800Hp at the crank, 670RWHP, 613ft.lbs. torq. @ 11lbs. boost. SOLD!!!
09-22-2015, 10:16 AM | #2 |
Drives: Blue Ray 2SS Join Date: Jul 2013
When I installed mine, I have a 13 2SS coupe, the single purple wire went to ground only for "show mode" through a toggle switch which I just taped off. The power for the tail lights was obtained through the harness that plugs right where the original tail lights plugged into. Hopefully that helps.
Paul |
