Old 03-29-2015, 08:48 PM   #1
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Send a message via AIM to SSE 4 2SS Send a message via Yahoo to SSE 4 2SS
First startup...
Here is the first start up of my new ERL 417 cubic inch aluminum block motor. AllPro heads, custom intake manifold with a huge plenum and very short runners, custom exhaust manifolds, twin 76/75 Precision turbos, 225 lb/hr Siemens DEKA race injectors, solid roller cam, 10.5:1 compression...
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
“If everything seems under control, you're just not going fast enough.” Mario Andretti
If you can turn, you ain't going fast enough...
SSE 4 2SS is offline   Reply With Quote
Old 03-29-2015, 09:06 PM   #2
forklord
forklord's Avatar
Drives: 2010 2SS
Wow....
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 03-29-2015, 09:22 PM   #3
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
That sounds awesome, should be a hell of a beast. Hope you can get it to hook. Throw in some pics of the engine when you can. Nice job.
HOJO is offline   Reply With Quote
Old 03-29-2015, 09:47 PM   #4
BrainleSS
Working on my 2nd one!
BrainleSS's Avatar
Drives: Camaro
That sounds great Robert, I'm expecting to be doing that very same thing in mid - April!
Well I hope.
Curt
[SIGPIC][/SIGPIC]
BrainleSS is offline   Reply With Quote
Old 03-29-2015, 10:12 PM   #5
blake-b
blake-b's Avatar
Drives: 2009 ZR1
That's audio porn to me
Old 03-29-2015, 10:19 PM   #6
Unreal
Drives: 2006 Z06
Very nice.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 03-29-2015, 11:29 PM   #7
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
+1. Love it! And I know how that feels!
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 03-29-2015, 11:44 PM   #8
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
As requested... And I apologize for only one pic per post. Darn iPad...
Old 03-29-2015, 11:48 PM   #9
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Another one... That is a 4" boost pipe feeding a 102 mm throttle body... Decided it was time to upsize from the factory original...
Old 03-29-2015, 11:48 PM   #10
hammdo
hammdo's Avatar
Damn, that is awesome! RJT color?
Can't wait to see some runs...
-Don
747 RWHP 794 RWTQ
Old 03-29-2015, 11:51 PM   #11
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
-Don
Yes it's a 2010 RJT. The hood is now carbon fiber thanks to Nathan Moreno...
This is a Mile and more car... It's way too heavy and geared wrong for 1/4 mile passes... At full throttle I'll shift into 5th somewhere well north of 200 mph... Calculated to be right around 227 going into 5th gear...
Old 03-29-2015, 11:51 PM   #12
phntmss
phntmss's Avatar
Drives: 2011 Camaro SS/RS
that sounds awesome!! only thing i didn't like about the video was when it ended haha. I look forward to seeing the numbers it puts down!
2011 SS/RS @ home 12/28/2010
phntmss is offline   Reply With Quote
Old 03-30-2015, 12:05 AM   #13
hammdo
hammdo's Avatar
Originally Posted by SSE 4 2SS View Post
This is a Mile and more car... Calculated to be right around 227 going into 5th gear...
Wow...
-Don
747 RWHP 794 RWTQ
Old 03-30-2015, 03:44 AM   #14
H-E
Drives: 2010 zr1 Camaro 2011 vert
Insane!......... Can't wait for the final numbers......... MPH of coarse
H-E is offline   Reply With Quote
