Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 06-07-2013, 09:54 AM   #1
Stoichiometric
Stoichiometric's Avatar
Drives: Stock
Distilled ice cubes
Two questions about adding ice to the heat exchanger reservoir;
How much ice do you melt during a typical track outing?
Have you ever made distilled ice cubes to minimize corrosion/scale in the heat exchanger system?
Stoichiometric is offline   Reply With Quote
Old 06-07-2013, 08:30 PM   #2
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
Or use clear ice from a clear ice maker, that is distiller water when clear ice is made. When ice freezes on a cold plate the impurities do not freez in the ice.
Skylane765 is offline   Reply With Quote
Old 06-09-2013, 06:00 PM   #3
SPOOKYGUNNER
ROCK
SPOOKYGUNNER's Avatar
Drives: 2013 ZL-1 TRIPLE BLACK VERT
HATE TO B IGNORANT BUT WHERE DO I ADD THE ICE ON A STOCK Z?
WHEN ONE AMERICAN IS NOT WORTHY TO BE FOUND...THEN WE AS AMERICANS HAVE LOST. POW/MIA YOU ARE NOT FORGOTTEN
SPOOKYGUNNER is offline   Reply With Quote
Old 06-09-2013, 06:11 PM   #4
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
In the reservoir for the intercooler heat
exchanger.
Sent from my HTC One X using Tapatalk 2
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 06-09-2013, 06:11 PM   #5
KlugSS
Guest
Posts: n/a
Distilled will cause more corrosion then filtered water.
Old 06-09-2013, 06:16 PM   #6
The Stig
knows 2 facts about ducks
The Stig's Avatar
Drives: ...and they're both wrong
How so? DI water is pure H2O.
Click to view my build thread
The Stig is offline   Reply With Quote
Old 06-09-2013, 06:42 PM   #7
KlugSS
Guest
Posts: n/a
Thats the problem. Distilled will pull minerals from the metals it comes into contact with. Filtered is a much better idea with less corrosion.
Old 06-09-2013, 06:57 PM   #8
The Stig
The Stig's Avatar
Isn't the intercooler heat exchanger system plastic and rubber tubing though? And wouldn't filtered cause more corrosion because it has other things in the water?
Old 06-09-2013, 09:34 PM   #9
KlugSS
Guest
Posts: n/a
Each their own really. Back in my 03 cobra days it seemed more people had their heat exchanger leak with distilled water. More then like either will do just fine, but i will always use filtered water.
Old 06-09-2013, 11:29 PM   #10
2012-1822
2012-1822's Avatar
Drives: Black ZL1
So you're adding liquid to the system, what happens when it gets full. I mean obviously you drain some out? And what is normally in there, antifreeze or just water, so once it's just water hadn't you better watch yourself if it gets cold out? Serious questions, cause I really don't know.
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
2012-1822 is offline   Reply With Quote
Old 06-10-2013, 06:56 AM   #11
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
I watch the ice fans at the track and I laugh. no messy melty bag of ice is going to keep you cool like an rx chiller.
joes407 is offline   Reply With Quote
Old 06-10-2013, 08:06 AM   #12
Cody6.2
Drives: 2012 Camaro 2SS
Cody6.2 is offline   Reply With Quote
Old 06-10-2013, 09:51 AM   #13
LIVEVIL
LIVEVIL's Avatar
Drives: Camaro
Is that why most manufacturers reccomend to mix coolant with distilled water? So that the cooling systems and engines corrode more? The same cooling systems and engines they warranty for year and years?
LIVEVIL is offline   Reply With Quote
Old 06-10-2013, 10:45 AM   #14
KlugSS
Guest
Posts: n/a
Because it saves their ass from people using some back country well water that you can see the metal particals.
