Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 05-11-2022, 07:37 PM   #1
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
og battery left me stranded.
It was only a matter of time, My og 2013 battery took a dive on me when i was at the softball park coaching my daughters 9-10 year old team. I new this time would come, good thing one of the parents had some jumpers.
What's a good battery to replace it with? No red tops they are junk, never had a good one.
jt
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 05-11-2022, 08:44 PM   #2
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
whatever brand just make sure it is an AGM battery...
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 05-11-2022, 09:37 PM   #3
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
jt
Still see some of the OEMs around but you would definitely need to check the date code. Still on original date stamped November 2012, always on a tender and add distilled water every year and do a refresh from the tender.
ZMEnow is offline   Reply With Quote
Old 05-12-2022, 08:42 AM   #4
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ
This happened to me, and my battery was fully charged (the car stays on a battery tender). Over time, the cells inside the battery wear out where it cannot hold starting power. Luckily a friend of mine had a portable battery jumper (It saved me a lot of grief and I learned a lesson). Now when I travel I make sure to have my portable jump starter handy.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'15 Malibu LTZ 2LZ Turbo
'14 CAMARO ZL1 Blue Ray Metallic
lbls1 is offline   Reply With Quote
Old 05-12-2022, 09:19 AM   #5
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I had a fairly new battery that would land the car in limp mode on a hot start. It was a warranty replacement, so I did not take it back. I added three additional grounds and brushed the paint off where the main ground on the engine connects to the chassis as well as where the battery negative connects to the chassis. Same battery, problem solved. If I had bought a new battery it would have fixed the problem for a while again, but I am getting tired of buying $200 batteries and want to have more time between replacements.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
CamaroCracka is offline   Reply With Quote
Old 05-12-2022, 09:30 AM   #6
Little Walter
Drives: ZL1
The SEARS Platinum AGM sold at Advance Auto or the Odyssey AGM, both sold in Group H7/ Grp 94R
Little Walter is offline   Reply With Quote
Old 05-12-2022, 11:08 AM   #7
tartagliazl1
I’ve already added 2 extra 2 gauge grounds to the car. Transmission to chassis and battery to body. It’s just worn out.
Old 05-12-2022, 11:19 AM   #8
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
jt
I bought the OE AC Delco from Summit. AGM, inexpensive compared to the store, and so far so good. There was a thread here about it a couple of months ago.
FasNuf is offline   Reply With Quote
Old 05-12-2022, 11:38 AM   #9
tartagliazl1
Just bought the Ac Delco from summit. Thanks fasnuf. $166 free shipping not bad.
Old 05-12-2022, 02:25 PM   #10
scott's45
Scott's45
scott's45's Avatar
Drives: 2012 2SS 45th Anniversary
I bought a new battery a couple of weeks ago just for peace of mind. I was still on the original one since the car was new....so it's going on 11 years this November. It never gave me a problem, but I figured I'd change it due to it's age. I brought the original battery back to Advance Auto to get the core charge refund and asked them to test it just for the hell of it. They said it tested fine, still had 620 out of 750 cold cranking amps left! I'm amazed after over 10 years it was still good. Guess putting it on a battery tender every winter really helps.
2012 2SS 45th Anniversary, Hurst short throw shifter, Stainless Power LT headers, high flow cats, SW Retro Chambered 3" cat back, CAI, Heritage grill, tinted windows, red/silver hash stripes, AAC LED sidemarkers, blacked out turn signals/tail lights, splash guards. 402RWHP
scott's45 is offline   Reply With Quote
Old 05-12-2022, 02:28 PM   #11
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Run a tender 365 days a year, including the winter hibernation.
0stones0 is offline   Reply With Quote
Old 05-12-2022, 08:13 PM   #12
ZMEnow
Ditto that, + annual refresh after topping off with water.
