04-19-2022, 01:47 PM | #1 |
Drives: 18 camaro zl1 Join Date: Dec 2020
Flex fuel issue
So my car is in the shop and the tuner/owner just told me they’re dealing with fuel pressure issues on e85. They said it’s apparently common and they’ve shimmed the high pressure pump in hopes to fix it. I have the dsx kit. Just want to get Inputs from you guys that have used this kit and if y’all ever dealt with this
04-19-2022, 02:06 PM | #2 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
I run E85 on my daily driver 2019 SS 1LE and I get about 12MPG on E85 and around 15MPG on 93.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
04-19-2022, 05:53 PM | #3 |
most cars can go to about e45-50 without any fuel pump changes...most choose to go with a voltage booster for the in tank low side pump instead of mods with the high pressure pump
04-23-2022, 07:41 AM | #4 | |
Dyno Show Queen LOL
id like to buy the 4 to 6 good piston and rods after the failure please.
04-23-2022, 10:01 AM | #5 | |
Drives: 2018 Cadillac CTS-V Join Date: Jul 2012
04-23-2022, 11:50 AM | #6 | |
Dyno Show Queen LOL
04-23-2022, 02:17 PM | #7 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
This is why I don't mess with that crap. "Oh it's soo simple", "E85 is soo easy to deal with"...yea, and then you find out you can't run this you can't do that your max is 40 if you have this but 27 if you have that you need a low side you need a hp dfi tb3 4x 50hdmi with a pip29 controller on the high side if your pulley is blue...it's not worth the aggravation.
04-23-2022, 03:13 PM | #8 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
04-23-2022, 04:57 PM | #9 | |
04-23-2022, 05:29 PM | #10 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Same here. And I’ve never had a problem with it and never been confused by any aspect of it LOL.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
04-23-2022, 08:07 PM | #11 |
GM LT stuff is by far the easiest platform to run Ethanol on with the flex fuel sensor. The ECU adjusts the tune on the fly for whatever percent Ethanol is in the system. All you have to do is log your car or have a dyno shop log the car and find out how much Ethanol the setup can run. Then you simply mix the E with Pump gas at the pump to stay around that percentage.
Most other platforms require being hard tuned for E which means if the Ethanol percent in the system changes then you have to manually adjust the Tune. Either way feel free to stay on 93 and get gapped by cars with less mods on E...
2016 NFG 1SS A8
04-23-2022, 08:12 PM | #12 | |
If even this is too much, you upgrade your fuel system (once) with a tune for 85%+ ethanol, and then you can put any mix of 93 and E85 into the tank anytime, basically "fire and forget". I can understand you personally don't want to mess with "that crap", but then just say that, no need to try and make it look worse than it is.
04-24-2022, 05:26 AM | #13 | |
04-24-2022, 08:49 AM | #14 | |
Either way It's not like any of these cars are cheap to buy and most that can afford them can afford a few extra thousand on fueling if need be.
2016 NFG 1SS A8
Tags |
dsx, e85, flex fuel, fuel pressure |
