05-19-2016, 07:56 AM | #1 |
Drives: 2018 Camaro 2SS Join Date: Mar 2016
High coolant temp
Hi everyone,so the last day i was cruising in traffic and while idling at a red light my coolant temp went to 242 degrees,and engine temp sensor got a litte over the center mark,should i be worried?
05-19-2016, 07:58 AM | #2 |
Drives: 2015 2ss Join Date: Jun 2009
if you've never done a coolant flush yet, i'd recommend it. 6+years on coolant is near end of life.
2015 Camaro 2ss, NicKey Performance built/tuned |
05-19-2016, 08:09 AM | #3 |
05-19-2016, 08:34 AM | #4 |
Drives: '23 LT1 A10 Join Date: Oct 2015
Mine was up to 215 the other day at a red light and 90 degrees outside.
24 LT1 M6 Sharkskin Metallic
05-19-2016, 08:48 AM | #5 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
05-19-2016, 10:13 AM | #6 | |
also, via italia!
05-19-2016, 11:21 AM | #7 |
Drives: 2013 Camaro 2SS RDP Tuned L99 Join Date: Apr 2013
05-19-2016, 11:32 AM | #8 |
Would rather be riding
Drives: No car no more Join Date: Jul 2009
Before you swap the coolant you need to figure out what's causing it to overheat, because 7 year old coolant will not be the cause.
It's low on coolant from a leak or something has malfunctioned such as the electric fan. Something is wrong if it hits 240 degrees, unless you are idling in the desert with the AC on high I suppose.
No dog in this fight anymore.
5th Gen owner 2009-2016. |
05-19-2016, 11:40 AM | #9 |
Started#gottalovethatblue
Watch out with Dexcool that stuff SUCKS! I've replaced intake manifold gaskets on every vehicle that came from the factory with Dexcool except my Camaro and Impala because they are too young still. If you switch make sure you get all of the Dexcool out though because that will gum up the cooling system.
05-19-2016, 11:55 AM | #10 |
Not sure, I don't have a gauge to tell me. I would imagine it would get pretty high especially coming into the summer months where our temps in Austin could reach 110F on some days. The normal temp in summer is around 95-100, so I could surely see this running hot but I don't think I should be concerned as the fans will be blasting away, (blasting hot air on the hot engine)
05-19-2016, 12:53 PM | #11 | |
Drives: 2013 Camaro Dusk 2SS/6 Join Date: Sep 2013
05-19-2016, 02:28 PM | #12 |
Drives: 2018 GT350 Join Date: Nov 2011
Mine will go up to 219 highest on a hot day with AC on, but usually is 192-194 crusing.
My tranny temp under NORMAL driving conditions doesn't see over 190.
Off to the Dark Side
05-19-2016, 02:36 PM | #13 |
You should change it though
05-19-2016, 02:48 PM | #14 | |
Drives: 2014 2SS/RS Join Date: Dec 2014
Ron
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
