Old 06-28-2015, 09:16 PM   #1
Cars and Tea
Cars and Tea's Avatar
Drives: 2013 Camaro 2SS/RS
Putting higher than 93 octane in a stock non tuned SS?
What can I expect putting higher than 93 octane in a stock non tuned SS?
I know I will not benefit from additional hp, power, etc. but will it run better?
I am going to the track which they have race fuel pumps and was wondering?
Cars and Tea is offline   Reply With Quote
Old 06-28-2015, 09:28 PM   #2
jrhagen
Drives: Camaro
High octane gasoline burns slower than low octane gasoline. The slow burn prevents engine knock when cylinder pressures are high. If your engine runs well and does not knock or ping on low octane gasoline, there is no advantage in switching to higher octane gasoline.
jrhagen is offline   Reply With Quote
Old 06-28-2015, 09:54 PM   #3
joeybsyc
joeybsyc's Avatar
Drives: 2010 Aqua Blue Metallic 2SS
In less words, no.
joeybsyc is offline   Reply With Quote
Old 06-28-2015, 09:54 PM   #4
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Being that the car is rich from the factory and still knocks about 4-6 degrees, if the higher octane prevents some of that knocking, you'll pick up a couple HP.
Tampa Tuning is offline   Reply With Quote
Old 06-28-2015, 10:06 PM   #5
agent5
Drives: 2013 Camaro SS (+RS) + Hurst+ DME
I think it's more a parameter of ignition temperature so when high compression ratio and heat are mixed with the fuel it won't ignite before the spark is met. It may burn slightly slower but that's a side effect, not the main reason to use it.
agent5 is offline   Reply With Quote
Old 06-28-2015, 10:10 PM   #6
Camaro Dude
Camaro Dude's Avatar
Drives: ‘13 1LE
Interesting, but curious..
What was the fuel's AKI number when you observed KR?
At what rpm did the KR occur at?
Camaro Dude is offline   Reply With Quote
Old 06-29-2015, 07:49 AM   #7
White14SS
Drives: 2014 Camaro 2SS/RS M6
Get tuned for it like I did, running sunoco 260 gt 100 unleaded. Picked up 30hp from 93.
2014 2SS/RS M6-ZL1 SHORT THROW-Z28 INTAKE-KOOKS 1 7/8 CATLESS HEADERS-NPP EXHAUST-TUNED BY STEVE AT RDP ON 100 OCTANE-446 WHP-412 WTQ
White14SS is offline   Reply With Quote
Old 06-29-2015, 09:50 AM   #8
Tampa Tuning
If you tune for a higher octane like that, you always need to run that level octane. That's why I tell guys not to add fuel oxygzers on tune day unless you plan to run it every day like that. Sure you'll get a higher number, but I dont like the risk Vs return if you dont run that adder every day because your traveling away from your favorate fuelling station
Old 06-29-2015, 10:36 AM   #9
White14SS
It works out for me it's 7 bucks a gallon but it's not my dd and I pretty much just cruise locally.
Old 06-29-2015, 11:24 AM   #10
Neuf Cruz
Neuf Cruz's Avatar
Drives: 2011 LS Black on Black 6speed
OP is stock!
Not bashing but I think tuning your car to run on basically "race Gas" for under 500hp is really not worth it. Many Mods you can do on pump gas to achieve this.
Roto-Fab CAI-Ported Throttle Body-Black Ice Isolator-Flow Master Axle Back-RX-Catch Can-Hurst Short Throw Shifter-Trifecta Tune\Ghost Cam
Phantom Billet Grill-Billet Fuel Door-Side Gills-Headlight Armor Black Out Kit-Zenik Rims-Lowering Springs-MGP Caliper Covers-Dome\Trunk\Footwell Lighting.
Neuf Cruz is offline   Reply With Quote
Old 06-29-2015, 11:51 AM   #11
rfopt
Drives: 2019 Corvette Grand Sport
Do you know what your WOT air fuel ratio is roughly? Was the sensor that recorded the air fuel ratio placed at the tailpipe?
rfopt is offline   Reply With Quote
Old 06-29-2015, 11:52 PM   #12
Bodywerks
Drives: 2015 2SS/RS/1LE
Originally Posted by Neuf Cruz View Post
OP is stock!
Or do the mods, bump up compression, and run the race gas permanently to pick up 30+ over what the mods would pick up. Just sayin'
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports.
Bodywerks is offline   Reply With Quote
Old 06-30-2015, 06:19 AM   #13
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
Roll that dice. Octane ratings for pump race gas are AVERAGE. So the gas you used one day, may have better octane rating than the next. Thus you just inserted a variable into the equation, risking problems. Use only enough octane to keep your car from knocking. Anything more is a waste. In fact you can actually lose power if your octane is too high.
I would never recommending tuning for a particular grade of racing fuel like that, but hey, it's your grenade.
For stock, and if you have 93 pump gas plentiful around you, tune for that and call it a day. If you want more, put headers on it. From a cost standpoint, considering that the Sunoco at 7 bucks/gal is about double what you pay, you could pay for those headers quickly than "renting" the HP through the gas. Using 93 and at say, 20 mpg, the headers could pay for themselves in about 8500 miles.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 06-30-2015, 01:37 PM   #14
Camaro Dude
Drives: ‘13 1LE
Please elaborate?
