05-01-2014, 11:39 AM | #1 |
Drives: 2014 2SS RS Coupe Join Date: Aug 2013
serious issue! Stuck throttle in sport mode.
The only thing after market on my car is a CAI. Now and then if I'm in sport mode my throttle will continue to rev and be stuck in 4000-5000 rpm even if my foot isn't on the gas. Only way to get it out is to shift down to Drive. Any ideas or help? Still under warranty.
05-01-2014, 11:44 AM | #2 | |
Drives: 2018 GT350 Join Date: Nov 2011
And you also didn't touch the throttle body butterfly, right?
Off to the Dark Side
05-01-2014, 11:44 AM | #3 |
Drives: 2014 2SS L99 Join Date: Mar 2014
No clue why it would only stick in sport mode. Let the dealer figure it out.
05-01-2014, 11:47 AM | #4 |
05-01-2014, 11:48 AM | #5 |
MAF sensor is probably messed up. Get a new one or wipe off the existing
05-01-2014, 12:03 PM | #6 |
TODAY!
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
05-01-2014, 12:10 PM | #7 | |
This issue is very rare. Usually if I give it about 15 seconds it will shift the rpms down. It's almost like you're revving a bike in very low gear at a very high rpm. |
05-01-2014, 12:17 PM | #8 |
That doesn't sound good at all. I would take the cai off and put on the oem air intake and go straight to the dealer.
05-01-2014, 12:17 PM | #9 |
Drives: 2010 ZR1 "Satan" Join Date: Nov 2013
Capt Obvious here: Do you have floormats?
Normally a fly-by-wire car will code if the TPS's don't match the throttle blade position. The idle is closed loop. It should close the blade further and further until the RPM is achieved. If it can't get the RPM down, it codes.
2002 Z06 "Blue Meanie" 11.36 ET
2003 Z06 in progress 2009 CTS-V "Spooky" 12.36 ET, bone stock at 1600 mi. Rainy day in Sacramento. Sadness. 2010 ZR1 "Satan" no times yet. 2013 Volt SCCA Solo2 #771 HS3. And a bunch of Duramaxes. |
05-01-2014, 12:35 PM | #10 | |
05-01-2014, 12:41 PM | #11 |
Chu no guat a hasa is?
Drives: 14 Jeep G Cherokee Overland HEMI Join Date: Jun 2011
This has happened to me before. I think it went back to normal after 10 - 15 secs. Has only happened less than a handful but no clue why it happens. I think I once did drop to D and back to S. And as I remember it happened when I gun it.
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
05-01-2014, 12:46 PM | #12 |
No, but if he pushed it, and for some reason it isn't resetting right, it could be a battle between the butterfly and the ECU for correct throttle position.
05-01-2014, 12:50 PM | #13 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
OK....so what is happening is that your putting the car in sport mode, and your getting on it pretty heavy, and the car stays in a low gear, keeping you above 4,000+ rpm.
This is normal. When you put the car in sport mode, it will shift earlier and more often...that happens instantly. But it isn't until you really get on it that the car really begins to drive aggressively, and will actually hold on to lower gears on purpose. If you don't continue to drive aggressively, after 10 - 15 seconds the car will shift back to a higher gear, dropping the rpms down. Now if your saying that even with your foot off the gas, the car is continuing to push you forward....like say the Toyota Prius misshap where the throttle was literally stuck, then yes that IS problem. But if you are able to use the brakes to bring the car to a stop and the rpms go down again after 10 - 15 seconds...I say its not an issue, and the car is working as designed.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
05-01-2014, 01:20 PM | #14 |
