05-23-2014, 12:18 PM | #1 |
Drives: 421 twin turbo LS, M6 Join Date: May 2014
Like new TR6060 2012 Camaro SS TUET12030--SOLD!
Selling my "Take Out" TR6060 (TREMEC PN TUET12030 E, GM PN 24264045) that is out of a 2012 camaro SS. It has almost everything needed to operate. This tranny would be great for anyone looking to do a modern drivetrain swap. It has extremely low miles and looks and shifts like brand new. The vehicle it was removed from was side swiped so the tranny is perfect and shifts amazing. There are zero problems with this tranny and you can see from the pics that its practically brand new.
Gear ratio of tranny SSR (M10): 3.01, 2.07, 1.43, 1.00, .84, .57, 3.28 (reverse) For $2600 you get everything pictured: TR6060 (M10) transmission clutch, pressure plate, steel fly wheel (used, but barely) Black leather shifter (ZL1 5.1 shift ratio) ($300 brand new) Flywheel bolts All sensors bolted to transmission Hard line Concentric Clutch Slave cylinder Other features of the new TR6060 transmission include: - Reduced friction in the shifter system courtesy of a new cam and anti-friction plunger to control the side load shift detents. - Forward and rearward shift detent grooves are broached on the front of the main-shaft with a spring-loaded anti-friction roller, for more precise control of shift detents and positive shift feel. - Anti-friction ball struts, sintered hubs and fine-pitch splines on all synchronisers for reduced friction between components - delivering improved shift feel and reduced shift efforts. - Wider, two piece gears with machined clutch teeth for more precise gear engagement and reduced potential for gear block-outs." If interested text or call John (four 0 eight) five 1 five - 5 two zero 5. http://i1315.photobucket.com/albums/...ps78395b95.jpg http://i1315.photobucket.com/albums/...pscd0feebc.jpg http://i1315.photobucket.com/albums/...psa2437905.jpg http://i1315.photobucket.com/albums/...ps3b23ade6.jpg Last edited by 70lsx; 08-08-2014 at 11:07 AM. Reason: Add pictures |
05-28-2014, 10:22 AM | #2 |
Casey Woodside
Drives: a very fun car Join Date: Jun 2010
Very interested where is it located
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w |
05-28-2014, 10:48 AM | #3 |
08-08-2014, 11:06 AM | #4 |
Sold!
Tags |
manual transmission, t56, tr6060 |
