10-12-2022, 11:29 AM | #1 |
Drives: 2023 ZL1 Convertible, 1998 Z28 Join Date: Jan 2013
ZL1 Rock Guards
What is the most recommended rock guards for a ZL1? I am getting PPF done in a week, but trying to make sure I have the most protection from road junk as possible.
2023 Rapid Blue ZL1 Convertible
10-12-2022, 11:31 AM | #2 |
Thank you Al Oppenheiser!
Functional + Cosmetic + $$ = ACSComposite
Functional + $ = ZL1Addons |
10-12-2022, 11:51 AM | #3 |
I already bought the car. Have paint correction, PPF, ceramic, and tint scheduled. I don't think cost matters at this point.
10-12-2022, 11:56 AM | #4 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
I've had ZL1 addon rock guard's on for nearly 3 years with no complaint's. Driven on dirt roads for years and track the car a few times a year. They have done well.
10-12-2022, 02:41 PM | #5 |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
Don't expect ZL1Addons to stand behind their products if you have any issues. Won't ever do business with them again.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
10-12-2022, 02:47 PM | #6 |
Drives: ZLE/DEMON/GLADIATOR/GSXR1000R/ZX10R Join Date: Aug 2022
I put ZL1 Addons rock guard on 2 wide body Challengers and ordered them for my ZLE.
Zero issues, and they did the job.
2018 Dodge Demon #1399 2020 Jeep Gladiator Rubicon 6 speed manual 2023 ZL1 1LE 6 speed manual ************************* 2018 Suzuki GSXR 1000R 2021 Kawasaki ZX10R |
10-12-2022, 02:48 PM | #7 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Effective and low cost = $15 universal mud flap. Works like a charm. ZL1 Addons on the front are much too short. You can go with what's effective or looks good the two things are different. These work but you trade off some of the aesthetics or looks and then some people need instructions with a full installation solution and hardware, too. It's a real toss up.
If you send me a PM I'll show you my setup. |
10-12-2022, 03:45 PM | #8 |
Drives: Camaro Join Date: Apr 2021
I have ZL addons front and rear. The fronts mostly hold on double sided tape and screwed into place at the very bottom, which for me personally resulted in mid-top part coming off together with the tape. I have to redo the tape every now and then, esp. when it’s rain season.
10-12-2022, 03:57 PM | #9 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
I’ve had ZL1 Addons (fronts only) for almost six years. Not a single problem with them.
I really don’t think you need rear splash guards. In six years of ownership, I don’t have a single rock chip behind either rear wheel.
10-12-2022, 05:21 PM | #10 |
Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
I put Rokblokz ZL1 splash guards on my ZLE. No drilling required and no tape required, so they can be removed and returned to original. I only used the fronts and they aren’t quite wide enough for the tires on a ZLE, but I think they would be on a ZL1.
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
10-12-2022, 05:53 PM | #11 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
ZL1 Addons splash guards on my car for 2 years now. No issues with them at all.
10-12-2022, 06:04 PM | #12 |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
Just wanted to note that I had a positive customer service experience with ZL1Addons.
The tape pulled away on one of the front rock guards on my 2016 because I had neglected to install the metal clip in the hole cut in the rock guard. ZL1Addons sent me replacement 3M tape, cut to fit, for both front rock guards. Not only did they do so free of charge, they included two extra sets of tape in case the problem occurred again. It didn't. There were no issues with the rock guards after I replaced the 3M tape and correctly installed the metal clips. I had around 40K miles of satisfaction with their rock guards before I sold my 2016, and this was one of the first things I added to my 2021 RS. |
10-12-2022, 06:10 PM | #13 |
Drives: Chevy Camaro Join Date: Aug 2022
I spent the money with the ACS versions front and rear, I am happy with them. I didnt like the spacers and gaps the ZL1 add ons have.
yes $400 for rock/splash guards.... They really match well and sort of blend in with the OEM black on the car I dont think you can go wrong with either ones, just get them on there and PPF For PPF I did Full Hood Full Bumper Full Splitter Full Fenders A Pillars PARTIAL Roof ( to moonroof ) NA on your vert Full side skirts Lower part of doors Panel in front of rear tire Mirrors (backs) Door Jams ( high scuff area from shoes) Door cups and 20% tint $3000 |
10-12-2022, 07:07 PM | #14 | |
The hold up I have on getting things started is looking out the back window looks like a fun house mirror. There is a line about 2-3 inches up from the bottom. Anything in that section is either stretched or shrunk. I had the same issue on my 2016 after a top replacement, and they had to replace the top a second time to correct it. Not a fan of thinking about that on a car I just bought on 10-03-22.
