02-13-2018, 08:13 AM | #15 |
Drives: ZL1 Mosaic Black Join Date: May 2016
Agitation is agitation. I try to fold there thickest Platnum microfiber twice and the soap is the lubricant...its all good.
02-13-2018, 01:50 PM | #16 | |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
BUT, I am ALL FOR experimentation, thinking outside the box, and using products for purposes that they were not intended in the course of learning. All that matters is how YOU think it looks.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
02-13-2018, 03:47 PM | #17 | |
I have used meguiars ultimate polymer paste wax for almost 8 years and it is fantastic. Meguiars polymer usually lasts for 3 to 4 months. My approach is to be able to use polish or rubbing compound when needed for scratches, this cant be done with a real sealant, ceramic coating or other more permanent solution. The meguiars ultimate paste wax does not give the depth collinite does and collinite does not give the longevity of protection that meguairs does. That is why I would not use meguiars ultimate paste wax first. Collinite is very very hard and if not exposed to the elements, one coat may last for 1 month. On my other vehicle, the meguiars and collinite bond very well together provided they are not done at the same time. |
02-13-2018, 04:25 PM | #18 |
Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
I think you might have missed Kirks point (maybe??):
-if there is a layer of Collinite between the paint anything on top of it....when the Collinite starts to “wipe/dissipate” off the paint....anything on top of it will go with it. For example, you can apply a 2-year ceramic coating on top of carnuba wax.....and no matter how durable the top layer is.....it’s coming off when the base wax starts to come off. This stuff is fun to discuss and experiment with, and your car looks great in the pics regardless (and even better in person I’m sure). I’m also guilty of WANTING to rub my paint, clean etc more than I probably need to. All this wax talk is making me want to try one of several higher end waxes I have sitting and have never tried. Wonder how that will look/effect my ceramic coating and Reload that’s on the car. Hmmmmm lol |
02-13-2018, 07:25 PM | #19 | |
I don't remember which Collinite that OP is using. I have used plenty 845 and 915 in my business. It does last longer than most waxes.
02-13-2018, 09:41 PM | #20 | |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
If you like Collinite that is all the matters, just my 2 cents.
02-14-2018, 01:20 PM | #21 | |
The base wax closest to the clear is a carnauba that does not last 3 months right? Lets say after the 3rd application, the 1st application starts to dissipate and layers 2 and 3 are about to go with layer 1 in certain areas of the car. You see, the wax does not dissipate everywhere at the same time; therefore, when coat 4 comes in it will cover areas where the first application has dissipated, extending the properties of the carnauba. Subsequent applications of carnauba, until the 10th coat, will constantly re-coat surfaces. Upon the 10th application, the car is polished and the polymer wax is applied. Polymer wax forms a chain of bonds that's stronger than carnauba, the polymer wax is much more heat resistant, and mineral resistant. Finally, its all about maintenance of twice a month alternating between the polymer wax and carnauba that replaces dissipated areas. All I have to do is wash and spray wax when not using carnauba or polymer wax... hence you have created a wax layered paint with a deep carnauba color and polymer wax shine. ...and it is so easy to put on a take off at this point!! no more than 1.5 hours!! |
02-14-2018, 01:24 PM | #22 | |
