01-24-2018, 02:29 PM | #15 | |
The only time you should be using pressure is when you are compounding or polishing, to engage the abrasives to remove defects. Doing anything else, washing, sealing, waxing, etc., use as light of pressure as possible. When you touch your paint think wipe gently, not scrub like mad. Using pressure will only put scratches in your clear coat, it won't get your car any cleaner or add more shine.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. |
01-24-2018, 03:07 PM | #16 |
Drives: 2017 Silver SS Join Date: Dec 2017
Thank you for the tip! I’ll just try a gentle wash and see how it goes after that, I don’t think it will work with how hard it was to remove from the windshield but hey you never know
01-24-2018, 03:08 PM | #17 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
I'd bet WD-40 or goo gone would remove it. I use WD-40 to safely remove tar.
01-24-2018, 03:51 PM | #18 | |
Drippin' Wet Auto Detail
01-25-2018, 10:59 AM | #19 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
1. Wash car with a good bug and tar shampoo
if still there 2. Clay bar since you used clay or if the sap remains 3. polish with dual action polisher
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
01-26-2018, 09:36 AM | #20 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
If the local high pressure car wash has warm wash water then it will pull it off. Sap is just like pancake syrup, just needs to be warmed up and then soapy water applied to get it off. What doesnt come off then go over the vehicle with a clay bar. After that recoat the vehicle with a sealer/wax of some sort.
01-26-2018, 08:58 PM | #21 |
So washing didn’t work, I used hot water in my wash bucket but it just sort of smeared it in the paint. I guess I’m on to claying the car
Thanks for the help everyone |
01-29-2018, 11:57 AM | #22 |
If it doesn't work, let me know. I can probably send you a sample of CarPro Tar or Gyeon Tar for you to try out
01-29-2018, 12:02 PM | #23 |
Retired from Car mfrs....
Once Again, mineral spirits on a rag will get it, done it many times, paint safe.....
01-29-2018, 02:31 PM | #24 |
Do I need to dilute the mineral spirits? It scares me because that’s pretty much paint thinner isn’t it?
01-29-2018, 02:32 PM | #25 |
01-29-2018, 02:39 PM | #26 |
Mineral spirits has no effect on cured paint and clearcoat. It’s the cheapest option, but if you want to buy a product, any of bug/ tar products will work. I use stoners tarminator
01-29-2018, 02:44 PM | #27 |
Hand sanitizer or IPA will work as well.
01-29-2018, 03:44 PM | #28 |
Thread Tools | |
