02-22-2018, 02:44 PM | #15 |
Drives: 2019 2LT 2.0T M6 Riverside Blue Join Date: Jan 2018
Whats the point? Just get the overkill supercharger for your lgx.
02-22-2018, 03:37 PM | #16 | |
Drives: ZL1 ATS-V CTS-V C7Z Range Sport SC Join Date: Mar 2016
LF4 Engine, trans, harness for sale $9999 shipped |
02-22-2018, 09:42 PM | #17 | ||
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
02-23-2018, 03:45 AM | #18 |
Drives: 2017 SS 1LE Join Date: Mar 2017
Try it if you have the funds, that is what hot rodding is about...
02-23-2018, 08:32 AM | #19 |
Drives: 2SS 1LE Join Date: Oct 2011
The shorter block of the V6 is probably a better fit for that car as far as handling dynamics and a car actually intended to run turbo usually has good mod potential and you can get significant increases by just simply mods like tunes and exhaust, vs. NA cars that need a whole lot more mods to usually achieve the same % increase in whp/wtq. Think GT-R, etc. Good twin-turbo setups are usually some of the best base-setups. Yeah yeah, for 7+grand you can put a supercharger on a V8, but that's the point, you'll spend a lot more money to get gains.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
02-23-2018, 09:04 AM | #20 | ||
Drives: 2017 1LE Join Date: Jul 2016
Where can I find more info on that swap? Sounds pretty cool. Would love to see pics/vids if they are available
17 Summit White SS 1LE PDR / Borla S type Catback / XPEL Ultimate PPF
02-23-2018, 10:26 AM | #21 |
Tread Marks
Drives: 2016 Hyper Blue Camaro 2SS Join Date: Apr 2017
Horrible idea...
02-23-2018, 12:35 PM | #22 |
Drives: 2021 300 Join Date: Jan 2015
Autos these days do not have standard frames, the aluminum cross sections and engine mounts. and cradles are constructed for that setup. There is a frame jig for each engine setup. Gone are the days of common motor mounts and trans supports. Not even talking about the computer and the wiring harness switches that would have to be made. There is no plug and play in the new car world.
02-23-2018, 12:42 PM | #23 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
The shorter block is offset by the higher center of gravity (significantly taller & wider at the top end). With that and the required charge air cooler setup in the front, I'm not so sure the LF4 would help in the handling department. I agree with you on the ease of modification though, with a calibration change only, though I do wonder how much GM left on the table before running into mechanical limits. I'd be interested to see the full dimensions and weight of the LT1 and LF4 (both with all needed cooling included).
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
02-23-2018, 04:33 PM | #24 |
Drives: 2023 Camaro ZL1 Join Date: Jan 2016
I remember seeing an interview with a Caddy engineer and he said they didn't like the weight distribution of the LT1 in the ATS-V- so obviously they tried it.
At a local "Find new roads" event a couple years ago, I asked a camaro powertrain engineer if the camaro would get the ATSV motor. He said no, the only turbo motor would be the 4cyl. I told him they were missing out on selling product to the FI/high elevation guys . . . I think the V6tt swap into the SS is a cool idea. |
02-23-2018, 04:46 PM | #25 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
I love the idea. I hope you actually go through with it in spite of all the nay sayers.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
02-24-2018, 11:21 AM | #26 | ||
02-24-2018, 12:34 PM | #27 | |
Drives: 18 1LE, 12 Regal GS Join Date: Jan 2018
If you want more power, but an SS or get a used ATSV, as already mentioned. |
02-25-2018, 02:58 AM | #28 |
Drives: 2004 Pontiac Grand Prix Join Date: Oct 2010
As true as that is I wonder what would be the cost difference between them switching to an SS or an ATS V, doing a motor swap, or building up the internals on the LGX engine to take two turbochargers.
If someone is selling the motor for $10,000 then you would have to consider the cost of getting it in his Camaro and getting everything to work. Ultimately it might be cheaper for them to build up the motor and bolting on a procharger of sorts. |
