03-03-2024, 04:27 PM | #1 |
Drives: 2LT RS Yellow Convertible Join Date: Aug 2016
KeyFob RF signal jammer
Hi All,
2 days ago when I tried to lock my car, both the KeyFob and also the door handle button did not lock my car door. It turned out that someone close by was watching me and used a signal jammer to mess with the cars key locking mechanism. For the experts here are some questions: 1. any ideas how many feet someone has to be away from my car to jam my keyfob signal or door handle button 2. I searched for jam device detectors on the web but did not find a good product. Any recommendation? 3. Any other cool device which can help preventing or recording people which are trying to get into the car? Last note: I am really shocked how easy it is to get into my Camaro. Looking forward for some great expert information!
Gold Rush
03-03-2024, 09:12 PM | #2 |
Who Needs to KNOW?
Easy fix, 3 step process
1. buy cookie tin. 2. Eat cookies 3. Designate cookie tin as key storage Keep few cookies in there as reward to returning keys to cookie tin every night. No need to worry about recording codes, they are rolling, so once used, they expire. You would have to actively press the button on fob and record for that attack to work, meaning, at that point, you *already* have access to the fob.
ing for grip.
03-03-2024, 09:43 PM | #3 | |
Drives: 2020 3LT Camaro 3.6L 1LE Join Date: Feb 2020
Probably copying the code to steal at a later date. Not to "F" with you. Buy a faraday pouch: https://www.amazon.com/s?k=Upgraded+...ref=nb_sb_noss |
03-03-2024, 09:55 PM | #4 |
Drives: 2016 Camaro SS Vert. Join Date: Apr 2017
That sounds like someone used a Flipper device on your car. For those who don’t know what that is just google it. Some people think it’s funny and do it just for kicks.
03-03-2024, 09:57 PM | #5 |
Drives: 2016 2SS Convertible Join Date: May 2012
What makes you think someone was jamming your key fob? There are a number of devices such as the electronic sensors to open store doors that can interfere with the fob. The battery in the fob might be getting weak and need to be replaced.
I don’t have any answers for your first two questions. A good dash cam might give you what you want for the third question. You might want to program the car to automatically lock the doors after they close. |
03-03-2024, 10:35 PM | #6 |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
When was the last time you changed your key fob battery? I had this sort of intermittent issue when my fob battery voltage was low (but not anywhere near totally discharged). I swapped it for a new one, which solved the intermittent operating issues.
03-04-2024, 07:04 AM | #7 | |
Drives: 2016 Camaro 2SS Join Date: Jun 2016
I have a metal key box that is just used to hang keys. I thought since it was metal it would block any signal, but when I held it lose to the car, closed, with the fob inside, I could still unlock/lock the car. So I use a dedicated faraday box and pouch. |
03-04-2024, 12:58 PM | #8 | |
Hot Camaro
The cookie tin type thing will often work because the metal is exposed along the top ring where it will come in contact with the lid. |
03-04-2024, 01:11 PM | #9 |
Faraday bag will definitely block the signals
'20 ZL1 1LE A10,
03-04-2024, 02:55 PM | #10 |
Who Needs to KNOW?
I'll have to test my double wall retired coffee cup for effective range and then toss in cookie tin for comparison. I dont need 100%, just reduce effective range significantly so that attack takes too long to be effective.
ing for grip.
03-04-2024, 03:03 PM | #11 |
Instagram: Sangstah
Faraday pouch on amazon is cheap.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
03-04-2024, 03:47 PM | #12 |
Who Needs to KNOW?
But cookies dont taste as good.
ing for grip.
03-04-2024, 03:47 PM | #13 |
Drives: 2023/2SS/1LE/RadiantRed/A10 Join Date: Jul 2022
I love that I never have to touch my keys. My car locks itself and the button on the door unlocks it when I walk up with my keys in my pocket. I’m fortunate that I don’t live in a dangerous neighborhood. I’m also not into conspiracy’s, so I don’t need to put foil hats over me or my key fobs.
2023/2SS/1LE/Radiant-Red/A10/Sunroof/Copper-Free-Breaks/Navigation —— Order History: 6/17/22-1100, 3/7/23-3000, TPW-4/3/23, 4/4/23-3800, 4/8/23-Delivered
03-04-2024, 06:22 PM | #14 | |
Tags |
rf signal jammer |
