Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 06-26-2016, 08:04 PM   #1
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
The original th400 h/C car about to make some moves this fall!
Went out for a few test hits yesterday. Got gears done, FTI restalled my converter for my GPI cam.
93 degrees out 60-70% humidity DA over 3000ft
Car went 11.33 on a soft launch 1.55 60ft
Tried to push a little more
Went 11.31 1.54 60ft
The motor cut off and came back on during that pass on the middle of 2nd gear for some reason! Probably had 11.20 on the run
Look for more to come! The car is almost ready to make a big move on the list
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 06-26-2016, 08:21 PM   #2
MoeIv
MoeIv's Avatar
Drives: IOM 2SS/RS
Right on! Good luck getting into the 10's really impressive
MoeIv is offline   Reply With Quote
Old 06-26-2016, 08:31 PM   #3
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Need a power adder in your life!
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
ttshovel is offline   Reply With Quote
Old 06-27-2016, 07:44 AM   #4
Bad70supreme
Thinking about a power adder at some point. But it's always been my plan to run 10s on motor before I did that.
Not sure if I want nos or a blower yet.
Old 06-27-2016, 07:49 AM   #5
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
I think it would be quicker with 305/45s
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 06-27-2016, 07:51 AM   #6
Bo White
Bo White's Avatar
Your at #20 with those passes
Totalled:
Old 06-27-2016, 09:30 AM   #7
Bad70supreme
Yeah I am kinda pissed the motor cut out on that .31 pass.
I am going to go over some things and get back out there. If I can go 11.1xx in this heat I am looking real good for fall!!
Old 06-27-2016, 01:40 PM   #8
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Doing work!
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 06-27-2016, 03:17 PM   #9
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
Impressive. What's your trap speed?
camarosspower is offline   Reply With Quote
Old 06-27-2016, 04:47 PM   #10
Bo White
Bo White's Avatar
I left the power adder world. Haven't looked back.
Totalled:
