11-04-2017, 09:32 AM | #15 | |
Drives: 2017 Camaro SS FIFTY Join Date: Dec 2016
11-04-2017, 09:33 AM | #16 |
Haven't tried it yet but the Tech told me to put on the flashers then hold the start button for up to 15 seconds (foot off the brake).
11-04-2017, 09:37 AM | #17 | |
When I travel I will NEVER be able to take this vehicle to the airport. FML. |
11-04-2017, 09:50 AM | #18 | |
Drives: Camaro 50th anniversary edition Join Date: May 2017
I put the foot on the brakes. You mean the warning flasher right. I will try.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
11-04-2017, 09:56 AM | #19 |
Retired from Car mfrs....
Same as vette:
The Corvette MAY be shipped in transport mode. To remove the car from transport mode, turn ON the four way flasher and place the driver’s foot on the brake AND on the clutch if it is a manual transmission. Press and hold the Start button for approximately 15 seconds. At this point the engine will START, but CONTINUE to hold the start button for approximately 15 seconds. Information will display on the center of the cluster that will indicate when transport mode has been turned OFF. Transport mode can be entered using the same procedure. Be aware it does not cut the power a whole helluva lot.... |
11-04-2017, 10:00 AM | #20 | |
But....many don’t... |
11-04-2017, 10:12 AM | #21 | |
EDIT: I tried this yesterday with foot on brake and held button for a count of 15. Car started and on the DIC it shows Transport Mode On. Didn't see any other behavior than that. Had to follow the same process to turn it off. Last edited by AmericanMike; 11-05-2017 at 08:50 AM. |
11-17-2017, 07:53 PM | #22 |
Well....another Friday and another dead battery. Not quite two weeks ago I had the problem. Today I bought a battery tender on sale at Costco and thought I would install it but realized the car was dead when I opened the door. ugh. Tomorrow I'll call roadside assistance for another boost after I install the cables under the hood.
Any chance my LED backup lights with a resistor attached is draining this thing? That is the only rogue mod I have done. |
11-17-2017, 08:03 PM | #23 |
I would rip it out see if it makes a difference.
11-17-2017, 08:19 PM | #24 |
yeah my thought too. Got to get the damn thing started first to get the trunk open!!
11-17-2017, 08:21 PM | #25 |
Open the door pull down the Rear seat and climb through and pull the trunk release
11-17-2017, 08:23 PM | #26 |
convertible.........rear seat doesn't go down.
11-17-2017, 08:44 PM | #27 |
Thank you Al Oppenheiser!
There’s a keyhole on the top of the back seat to pop the trunk.
See: http://www.camaro6.com/forums/showpo...03&postcount=5 |
11-17-2017, 08:53 PM | #28 |
Drives: 2018 2SS Coupe A8 Join Date: Nov 2016
Did the lack of window indexing cause a problem?
OP,
If the battery is dead and you open the car door I assume the window will not "index"(ie lower itself by an inch or so when you pull on the door handle). I also own a vert and wonder if this would cause the door to stick shut, the window to pull out part of top or even cause the window to break. Wha happened with yours? |
