12-02-2016, 03:22 PM | #15 |
Drives: 2017 Camaro; 2017 Acadia Denali Join Date: Jun 2016
12-02-2016, 03:27 PM | #16 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
I don't think the interest is there to make it profitable. I've already got most of it worked out on paper. The only thing I haven't figured out yet is what I'm going to do about pistons... I'm sure not going to buy them from ZZP. I have a stock 2.0 piston on the way also, I'll send it to Wiseco and see what they can do for me. Rods are easy, and I've already got a source that makes my forged LFX rods for me. It's a shame I can't use the LFX rods, that would make things REAL easy.
12-02-2016, 09:37 PM | #17 | |
I'm sure the cam timing in the stock tune isn't optimized for maximum performance. Probably a mix of minimum allowable performance where needed, but more focused on the emissions, and fuel economy. They say these engines don't need an egr valve because of the variable valve timing, that tells me it's probably too focused on emissions. Sent from my iPhone using Tapatalk |
12-04-2016, 05:01 PM | #18 |
If you count going in the hole buying random GM parts to test/play with a job, you're welcome to join any time
I need to win the lotto myself. |
12-08-2016, 06:02 AM | #19 |
Drives: 2017 Camaro 2.0T RS Join Date: Jul 2016
I would definitely be interested... But wouldn't be purchasing till 2018 some time. If when you crack open the spare block and find some extra meat in the web of the bore, would you consider a bore job and custom pistons? Also, after stroking the LTG would you be worried about the stock redline (or even a slightly higher one) or would the stronger parts make this a moot worry?
12-08-2016, 07:50 AM | #20 |
Drives: camaro Join Date: May 2013
What am I missing here? Why dump so much $ into the 4cyl? Shouldn't you just buy a v8??
Hyperblue/JetBlack |
12-08-2016, 08:41 AM | #21 | |
Same could be asked of the guys modding the V8's... Why not buy a Ferrari or an Aston or something (extreme example maybe, but it makes my point I think) |
12-08-2016, 08:43 AM | #22 | |
12-08-2016, 10:21 AM | #23 |
12-08-2016, 05:14 PM | #24 |
12-08-2016, 07:22 PM | #25 | |
Drives: Camaro 2.0t, 300zx TT, LSTT Mustang Join Date: May 2016
Back in the late 90's my little 1.6 civic used to mop up mustangs and vettes all the time. I can't even count how many times some cocky a-hole pulled up next to me just to run his mouth about how great his v-8 is, in some attempt to impress the girl with them in the car. It was just priceless to hand them their own ass, slow down and ask "what happened?" While the female in the car is cracking up. You need much more power these days, but it's not that hard to pull 800+whp out of a 4 cylinder. It's mostly going to come down to, what else besides the motor will be a weak point. |
12-08-2016, 11:41 PM | #26 |
You've underestimated the 4cyl. You don't need to dump that much in to make V8 numbers. A car with a *good* tune, e85, down pipe, and 3 inch exhaust has been 12.1 in the quarter. You're talking less than $2k in mods and tuning. That seems pretty cheap to me! I know Jason is discussing a stroker idea in this thread, but very few people will go to that extreme.
12-08-2016, 11:45 PM | #27 | |
The weak point of my Camaro is the clutch. It can barely hold on with the stock power. |
12-09-2016, 09:32 AM | #28 | |
