TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Tuning / Diagnostics -- engine and transmission
Old 06-17-2015, 11:19 AM   #1
supergt99
supergt99's Avatar
Drives: 2013 Camaro SS 1LE
Throttle settings in hp tuners
What settings should I change to make it like the throttle controller that people talk about on here? No sense in buying that if I can tune for it. Does the throttle actually open faster? Or it just going wot sooner ?
supergt99 is offline   Reply With Quote
Old 06-17-2015, 04:26 PM   #2
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
You cant on the LS series engine. It will go into reduced power
Tampa Tuning is offline   Reply With Quote
Old 06-21-2015, 08:07 AM   #3
Tampa Tuning
Corvette Camaro Cadillac Charger tuner in Tampa Orlando Florida
I got a PM about this thread so here was my response:
Ill check out the thread, but I thought the OP was asking how to adjust the throttle response in the tune and you cant because it will go into reduced power. That's with or without the VTC.
You can just add the VTC to a calibrated car, but you cant adjust the mapping of the throttle in the LS series in the tune
I wont calibration a vehicle with the VTC on it. You'll have to take it off prior to arrival, and if you want you can reinstall it later. The VTC broadly changes only the sensitivity of your gas pedal only. It adds no performance for Horsepower. So when Im calibrating my low end performance, I cant have and artificial adder interfering with the tables im trying to calibrate.
