dave@hennessey
Old 08-20-2020, 01:31 PM   #1
rmills
Drives: 2011 camaro 2 SS
ticking noise
Hey guys ive got a 2011 Camaro SS L99. on cold start up theres a ticking noise that only lasts for about 2 seconds, then i dont hear it again. sounds like valve train but not sure how worried to be about it
rmills is offline   Reply With Quote
Old 08-20-2020, 02:09 PM   #2
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
mods? could be the start of an exhaust leak...how many miles on the car?
l8tr
PEACE
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 08-20-2020, 02:21 PM   #3
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
More than likely an exhaust leak. As the metal heats up, the gap closes. Now, the hard part is finding it. A shop would have a smoke machine that might help.
It is possible that lifter is going bad and has to pump up, but start with the exhaust.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
CamaroCracka is offline   Reply With Quote
Old 08-20-2020, 02:50 PM   #4
chevyz1
Wife named it "Ghost"
chevyz1's Avatar
Drives: 2012 Camaro Summit White 2SS/RS M6
Seems like a lot of LS motors with age seem to have lifters get a little sticky or bleed down as the oil thins out. I have a 2000 GMC with a 6.0L with 130K miles on it and it will be a little noisy/ hear small tick at startup. I know these motors are really different, but I've done a few things that have helped stop it on the truck. I have done the seafoam and that helped a bit, but I've also added a little bit of marvel mystery oil and then the Lucas oil additive and it doesn't do it any more. Anyone have any other experience trying that on the LS3 or L99? Kinda old school, but Might give it a try to see if it helps.
2012 2SS/RS Camaro M6 Summit White
chevyz1 is offline   Reply With Quote
Old 08-20-2020, 05:08 PM   #5
IOM Bullet
Drives: 2010 2SS RS LS3
If the ticking/knocking sound is coming from the rear, you may have the dreaded "Trunk Monkey".
Hopefully that is the root of the ticking.
IOM Bullet is offline   Reply With Quote
Old 08-20-2020, 06:48 PM   #6
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Sounds like the dreaded afm lifters. Some Early L99s Have/had faulty lifters that would leak down. Tic tic tic on startup until the lifters pumped up. Usually within a few seconds. Doesn’t do it every time but randomly. Some had there’s replaced under warranty...me being one of those.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 08-21-2020, 06:50 AM   #7
myold88
myold88's Avatar
Drives: SUMMIT WHITE 2SS/RS CAMARO
Bingo, finally the answer. L99's are well known for lifter noise at start up.
My early 10 L99 lifters have never made a sound after 11 years. The trick is to
change your oil frequently. I've changed mine 16 times in 62,000 miles.
Also, there's nothing dreaded about it. It does no harm imo.
myold88 is offline   Reply With Quote
Old 08-21-2020, 09:15 AM   #8
wasthatacop?
wasthatacop?'s Avatar
Drives: 2010 2SS
I had a ticking that was constant. Ended up being a failed lifter that damaged everything else it touched. Hence the new crate engine. It was a slight tick, quieter that an exhaust manifold leak in my case.
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts,
1.4" BMR lowering springs
ZL1 factory rims
misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete
wasthatacop? is offline   Reply With Quote
Old 08-21-2020, 11:58 AM   #9
myold88
myold88's Avatar
Like Said you got to keep the oil clean.
Old 08-23-2020, 11:41 AM   #10
rmills
Thanks guys i can always count on good suggestions when i have a question. Keep it up
Old 08-23-2020, 12:18 PM   #11
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Maybe nothing, but what oil filter are you using?
Thinking a cheap filter and drain back valve inside leaking?
Corrections welcome.
FasNuf is offline   Reply With Quote
Old 09-18-2020, 11:59 PM   #12
Jrichards73
Jrichards73's Avatar
Drives: 2011 2SS/RS Victory Red
BTR fixed my L99 ticking noise, but now it has this weird lope to it and the car shakes at idle...
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB.
Jrichards73 is offline   Reply With Quote
