10-15-2019, 08:47 AM | #1 |
PSA Stop buying Chinese Hot air kits
People Please stop wasting money and time on Junk.
I have been receiving more and more tune requests from people who are shopping on Ebay for So Called Cold air kits which are really Hot Air kits Poorly designed then copied by chinese then make even cheaper. I would rather you run the stock air box because Less Cold air is still better than more Hot air when it comes to making power. This is a Very good Read and it explains everything you could ever want to know about cold air kits and how they actually work There is also a Part 2 to this done almost a year later. https://www.camaro5.com/forums/showthread.php?t=48202
www.jannettyracing.com
10-15-2019, 10:29 AM | #2 |
Started#gottalovethatblue
Agreed! When I bought my car the previous owner had a Hennessy cold air intake installed, minus the heat shield. Obviously it was then a hot air intake. I sold the intake and purchased a used roto-fab intake here because they have super top notch products. While most outlasting say they can't tell a difference with installing a cold air intake, I noticed a HUGE difference. I'm not saying Hennessy makes a bad product, just get a product that will do what you're wanting it to actually do and not just buy something cheap.
10-15-2019, 12:01 PM | #3 |
Drives: Chevy Camaro SS, Chevy Corvette, Join Date: Aug 2019
It is Like I always said "If you want Good Clean Oats you will pay a Fair Price" on the other hand "If you are satisfied with Oats that have been through the Horse then there are plenty of Bargains"
Do your Homework!! Dan |
10-15-2019, 12:43 PM | #4 |
Drives: 2014 2SS/RS Join Date: Jan 2018
First i want to point out that I am neither agreeing nor disagreeing with any of this. We all appreciate the time and effort you put into this and everything you share here.
My reason for jumping in here is to ask if you have tested any of these knock off kits in the same scenario? Apples to apples so to speak. Just curious.
2014 2SS/RS LS3/M6
10-15-2019, 01:50 PM | #5 |
still running the stock airbox after 4 years.GM spent more money than i will ever see designing the parts for this car.
10-15-2019, 06:47 PM | #6 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
The air intake with a pro charger is right above the exhaust manifold!
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
10-15-2019, 07:42 PM | #7 | |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
Air to air intercooler my friend, once the procharger compresses the air it is much hotter than under hood air regardless of where the fresh air is being pulled from. Then the compressed air pass's through the intercooler and gets cooled before entering the intake manifold
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
10-15-2019, 10:15 PM | #8 |
Drives: 2011 Camaro SS Join Date: Nov 2017
That’s why I’m holding out for a GM Z28 CAI.
My Little Mid-Life Crisis Cure!
First - 1997 Camaro 3800 Y87, M5, Green - Gone | Second - 1997 LT1 Z28, M6, Silver - Sold | Third - 1999 LS1 Z28, M6, Pewter, Almost Stock! - Sold Current - 2011 Camaro SS, M6, black, 1LE suspension parts - Current |
10-16-2019, 02:33 AM | #9 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
For the people interested in going fast the stock air box is a restriction. GM could’ve thrown $1,000,000 at it and it’s still a restriction...
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
10-16-2019, 04:55 AM | #10 |
Drives: 2011 Camaro 2LT/RS Join Date: May 2015
10-17-2019, 09:23 AM | #11 | |
I also look at data on a daily basis from these off brand junk, (the reason from my post) When the IAT is ridiculously high compared to ambient or climbs with RPM it is obvious they are pulling Hot air from under the hood. Rotofab, CAI, ADM are the best ones we tested in no particular order. We almost exclusively use CAI or Rotofab simply because they work the best fit the best and look the best. Just wanted to share for all the new guys joining the Camaro 5 community. Ted.
10-17-2019, 09:38 AM | #12 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
How does the official GM Z28 do in your tests?
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
10-17-2019, 09:42 AM | #13 |
Drives: 2015 2SS White Convertible CE/INDY Join Date: Mar 2016
I have a K&N Blackhawk on my SS... How do we know if the ones we have are any good versus the "Rotofab, CAI, ADM" brands?
joe...
ARH LTH/HFC/Legato muffler, RDP Custom Tune, K&N Blackhawk CAI, Bigworm Blackout kit, ZL1 Rims, Phantom Grills, VMAX PTB
10-17-2019, 09:47 AM | #14 |
Very well, it was not available till years later but we have tuned many of them and like the results and data.
Ted.
