08-15-2017, 03:17 PM | #1 |
Drives: 2018 ZL1 Join Date: Jul 2017
brake fluid for track days
Can anyone tell me if it's OK to run DOT4 brake fluid in my 2018 ZL1?
I can't find a DOT 3 with high dry and wet boiling points like in DOT 4. There is no mention of anything other than GM DOT 3 in owners manual and performance supplement. My car has the 10 speed automatic. Thanks |
08-15-2017, 03:19 PM | #2 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
Dot 4 is not only ok, it is recommended by GM if you plan on tracking it.
I use Motul RBF600 |
08-15-2017, 03:31 PM | #3 |
Drives: '17 SS 1LE Join Date: Jun 2017
^ What Eric said. I've also been using Motul RBF600 in all of my previous track cars and have never had issues.
08-15-2017, 03:35 PM | #4 |
DOT 4 is preferred. GM puts DOT 4 in their Police cars but not their performance cars. DOT 5 is the one to stay away from.
08-15-2017, 03:45 PM | #5 |
That's what I was using in my 16 Vette, It's still weird that GM has all the DOT 3 stuff on the cap and in the book, I even went to dealer here in town and got a big bunch of nothing from service and parts guys. I will also be changing brake pads to Carbotech XP 12's along with the brake fluid to the Motul RBF 600 before first track outing. Thanks ! Tom
08-15-2017, 03:49 PM | #6 |
Drives: Sold Join Date: Mar 2017
A10 ZL1 here as well -- Just did a track day and I also run Motul RBF600 in my setup on an otherwise OEM car.
08-15-2017, 03:57 PM | #7 |
Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
Castrol SRF first choice, motul rbf600 second.
08-15-2017, 04:11 PM | #8 |
Mr Mey, how did your stock pads hold up?
08-15-2017, 04:13 PM | #9 |
I had 2300 miles on them going in to the day and they seem to be just fine as of now... I'll see about taking some pics tonight/tomorrow of them and post up..
But, I never had any fade on the pads all day and they were always there when i needed them. |
08-15-2017, 08:03 PM | #10 |
Drives: Lexus, ZL1 1LE, Ducati, Suzuki, Join Date: Jul 2017
Same here. I am switching out my dot 3 for Dot 4 Motul 600 which is recommended for tracking and for street use.
You might want to consider at some point swapping out the rubber brake lines for some stainless steel braided lines which will give you a firmer pedal too. |
08-15-2017, 10:20 PM | #11 |
Drives: 2017 SS 1LE Join Date: Feb 2017
08-15-2017, 10:46 PM | #12 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Motul REF 600
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
08-16-2017, 05:08 AM | #13 |
Drives: 2017 ZL1 Join Date: Jan 2017
how much have you guys used to do a flush?
08-16-2017, 06:55 AM | #14 |
Right about 2pints for home. Dealer used about 2.5 pints when they do it.
