Old 07-21-2017, 12:46 PM   #1
svenh44
Drives: 2010 Camaro SS
UMI trailing arms Rear-Toe-Rod-Kit
found these on ebay are these worth it since i have limited funds to buy something and want something a little better than stock (2010 2ss/RS 6speed)
UMI-Performance-2010-2013-Camaro-Rear-Trailing-Arm-amp-Rear-Toe-Rod-Kit-Black
Kit fabricated from 1” x 2” rectangular tubing
CNC machined mounting plates and bushing holders
Greaseable and fluted Energy Suspension polyurethane bushings
Direct bolt on, uses OEM hardware
Price:US $274.99 Buy It Now
svenh44 is offline   Reply With Quote
Old 07-21-2017, 05:05 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
Unless you race your car I would suggest going with OEM parts - in this case 1LE/ZL1/Z28 toe links and Z28 trailing arms; can't remember what I paid for these parts from the dealer but it was about the price of these, more or less. The OEM parts are "weaker" than aftermarkets so they will bend if you get into an accident rather than having your subframe bent due to the extra-strong aftermarket arms not bending. As for wheel hop and the like, unless you push the car real hard (race) then the OEM parts will give you all the extra stability you could ask for.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 07-26-2017, 09:13 PM   #3
Jrichards73
Jrichards73's Avatar
Drives: 2011 2SS/RS Victory Red
They are good, been around a long time, but get them here instead http://www.ws6project.com/user_stor/...oducts_id=3871
Same design as the BMR pieces
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB.
Jrichards73 is offline   Reply With Quote
Old 07-27-2017, 01:58 AM   #4
FKNGRSY
Drives: 2014 1SS
Anything would be an upgrade over the stock stamped steel arms. These look decent!
FKNGRSY is offline   Reply With Quote
Old 07-27-2017, 01:18 PM   #5
jksynergy
jksynergy's Avatar
Drives: 11 SW SYNERGY SERIES/14 1SS 1LE
I just installed the adjustable arms and can say they are worth it. Autocrossed only on them so far but watched my video from under the car and they keep the rear planted no doubt.
My thread is here:
http://www.camaro5.com/forums/showth...&highlight=umi
2011 Summit White Synergy Series Edition, the hot innocent woman named Ava that we show off around town, dressed in white complete with angel's wings. Sold, but never forgotten.
2014 1SS 1LE. Bama, sporting Red Rock Metallic demon's horns, when we are ready to get naughty and open a can of whoopass! Airaid, Spectre, Xpel,Bowler shifter Peddars, UMI, Ult Perf. Diode Dynamics, JRE Tune, XS Power battery,
Hooker Headers Blackheart exhaust,Powerbrake
InstaGram & Twitter: @jlouie62
FB: hangtimeracing
jksynergy is offline   Reply With Quote
Old 07-27-2017, 01:20 PM   #6
jksynergy
jksynergy's Avatar
https://youtu.be/9uZDme87Siw
FB: hangtimeracing
Old 07-28-2017, 06:16 AM   #7
Btrbimmer
Drives: 2SS 1LE Silver w/Recaro NPP
Originally Posted by jksynergy View Post
It looks like you are ready for a set of these: http://pegasuscnc.com/5th-GEN-CAMARO...luminum-1.html
-BtrBimmer
'14 2SS 1LE NPP Recaros
Btrbimmer is offline   Reply With Quote
Old 07-28-2017, 06:30 AM   #8
jksynergy
jksynergy's Avatar
Ya think? That's on the list for the near future. This is the 4th season of autocross and road course events for the car and it's about time for solid bushings.
FB: hangtimeracing
