06-15-2019, 05:02 PM | #29 |
That’s what I do too SSDan!!
06-15-2019, 10:25 PM | #30 |
Drives: 2017 Red Hot ZL1 M6 Join Date: Jan 2017
Where can you find the pink coolant that came with the car?
06-16-2019, 07:51 AM | #31 |
buy Dexcool 50/50 from any parts store. Prestone, Peak, etc make good ones.
06-16-2019, 03:38 PM | #32 |
06-17-2019, 09:11 AM | #33 |
People, just look for a 50/50 mix that is Dex Cool compatible! This isn’t rocket science you know!
12-02-2022, 10:39 AM | #34 |
Drives: 2019 Camaro 1SS 1LE, Riverside Blue Join Date: Jul 2019
I know this is an old post but figured I'd provide my 2 cents. If I read the owner's manual correctly, the coolant system isn't as closed as what we are all probably used to and evaporation should be anticipated. My experience is that 1/2 to a full cup is needed after a track weekend in the heat (Texas). As for coolant, I purchased a gallon of Dex Cool from the Chevy dealer for less than $20 plus some distilled water and do the 50/50 mix (again Texas). The coolant is orange but turns pink/red when mixed with water and run through the system. I have used about half of the gallon over the last 3 years and I track a substantial amount (30 days per year). Just keep the lower tank half full - you can just pour (slowly) into the top tank and it will drain down to fill the lower tank.
PDR, CAI intake, Kooks headers & exhaust, AP Racing front big brake kit, DSC Sport RT coil-over kit & suspension controller, G-Force driveshaft, Braile battery, Anderson Composites deck lid, CMS Roll Bar, Schroth ASM Harnesses, BMR rear cradle lock out, ZL1 front lower control arms, SLP rear toe rods, ACS ZL1 Side Skirts, Apex 19x11" wheels.
12-02-2022, 11:28 AM | #35 |
Drives: 2023 ZL1 A10 Join Date: Nov 2021
Padge23, Thanks for the heads up . I don't frequent the track, but not out of the equation on a Camaro Club day in the future sometime.
2023 ZL1 A10 Shadow Gray Metallic
08-05-2023, 08:46 AM | #36 |
Drives: 2017 2LT Garnet Red Join Date: Dec 2011
Thanks everyone for the help! I have had 3 Camaro, a 2000, and 2015 and to be 100% honest never check or added coolant!
But in 2017 got a Convertible v6 and since I never thought about it until last week and when I went to look the top tank was 1/2" below the Cold Fill line and the bottom was bone dry. I only have 52K and do mostly longer driving and live in the midwest. But read this forum and got some Dexcool 50/50 and added it to the bottom tank to it's fill line and topped off the top, so thank you!! I never got a over temp warning but was very surprised that the top tank was below the fill line and got worried when a few said that there is a leak or Head Gasket issue, so I check the dip stick and had no cloudy and since I do my own oil changes never have seen cloudy oil. So from what I understand this is normal to have the top tank up to 1/2 an inch below the cold fill line? I did fill it and 1/2 way on the bottom tank I started the car for and with the top cap off it started to rise when it got hotter and the small top hose was getting very warm while the larger radiator hose was cool. Then after about 5 min I shut off the engine and the coolant level went down when it got cooler. This sound normal? Thank you everyone! Christopher |
08-05-2023, 09:30 AM | #37 | |
08-05-2023, 10:41 AM | #38 |
Drives: 2019 Summit White ZL1 Join Date: Mar 2020
DI water (Deionized Water) is a no go for your coolant system!!! DI water will eat your Aluminum radiator and any metal it contacts short of Stainless Steel.....perhaps you mean Distilled water?
08-05-2023, 12:11 PM | #39 | |
Thank you Al Oppenheiser!
Yes it's counterintuitive. Chevy_Things(TM). |
09-14-2023, 05:55 PM | #40 |
Drives: '23 2SS RSblue 6MT, sold '19 ND2 Join Date: Dec 2021
This stuff does evaporate. The bottom I had exactly at the half mark in probably December of last year. I recently topped it off with some dexcool, not alot but maybe 8-10oz max
'23 2SS, 6 speed, NPP, Copper-free brakes, 56V Carbon Flash Rims, Riverside Blue
1LE sway bars EOS front splitter 5-6-22:1100, 7-19-22: 3000, 8-3-22: TPW 8/15/22, 10-4-22: ETA 10/13/2022 10-15-22 6000 |
10-06-2023, 12:26 PM | #41 |
Drives: 2017 2SS A8 NGM, 2012 Yamaha FZ8 Join Date: Jan 2017
Funny to see this because I checked my oil the other day and noticed my overflow tank was 3/4 empty. Really surprised me because I've always thought the coolant system was a closed system, unless you have a leak.
10-14-2023, 03:52 PM | #42 |
Topped off my coolant today, after seeing this post a few days ago.
RUXIFEY Smoked LED Side Marker Lights / Black SS emblem on rear bumper / Blue SS vinyl overlay on front bumper emblem / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint RE Audio RFX10D4 10" Sub / Hand-made sub enclosure / Hifonics Zeus ZRX1200.1D amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
