Old 08-28-2018, 09:54 AM   #15
fdny
fdny's Avatar
Drives: 2019 ZL1 (Factory Ordered)
Originally Posted by Camaroguy555 View Post
Some people are going to call me crazy but I swapped mine out for Redline 75w140 and all the groaning went away. The other benefit was better clutch engagement (car was way smoother in tight turns). I did track the car regularly which is why I went with 140 weight but even in street driving there was no noticeable downside here in Colorado winters. I am a huge fan of Redline fluids in general, and they do make a 75w90 but I just wanted to share my experience.
You're not crazy at all.....Red Line fluids set the bar, nothing better.
2022 ZL1 1LE (on order # BGSDW8)
Trying Patiently to Wait
fdny is offline   Reply With Quote
Old 10-08-2018, 04:01 PM   #16
Chef-j
Drives: 2018 Camaro 1SS
Bumping old thread.
Planning to do differential fluid change soon. Thinking Redline 75w90 or OEM (but OEM fluid seems to be little confused.)
2018 1SS 6MT: SOLD
Chef-j is offline   Reply With Quote
Old 10-08-2018, 05:40 PM   #17
Marko
Marko's Avatar
Drives: Camaro
I’m really surprised at the low miles you guys are changing the rear diff fluid. My 18 SS has 3300 miles on it.
Haven’t changed mine yet
Marko is offline   Reply With Quote
Old 10-22-2018, 07:45 AM   #18
KCelsius
KCelsius's Avatar
Drives: 2018 Summit White 1SS 1LE
My 1LE is at 1600 miles and I just did the rear diff fluid yesterday and another oil change.
Oil wasn't too dirty but the rear diff fluid definitely looked like a change didn't hurt. The magnetic plug picked up quite a big of gunk and I'm glad it's out the car now. As the fluid was draining you could see some metallic material coming out - just refilled with oem fluid and it was super easy. Better than paying $200 at the dealer when materials cost $30...
KCelsius is offline   Reply With Quote
Old 10-22-2018, 08:23 AM   #19
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Did my SS diff at 1000 miles. Felt like it was good to get any break-in material out of the gear oil.
Old 10-22-2018, 01:33 PM   #20
Jhunsberger
Jhunsberger's Avatar
Drives: 2017 Camaro 1SS M6 (SOLD)
Just did my diff with OEM fluid, and M6 trans with redline DT4, had 13k on the car. you can certainly tell a difference in the trans, the the rear diff looked like it needed it.
Stock: 416hp/427tq, 12.21 @ 116.80
Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft.
Tuned by EFX Tuning 688hp/632tq
Best 1/4 to date: 10.705 @ 131.92
Jhunsberger is offline   Reply With Quote
Old 10-23-2018, 02:02 PM   #21
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I believe it states in the manual to change it at 1500 miles. That is why it is fitted with fill and drain ports unlike older GM rears to make it easier for regular service intervals. These 8.5 rears have less back lash compared to the older stuff.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 10-23-2018, 02:04 PM   #22
KingLT1
KingLT1's Avatar
Originally Posted by Chef-j View Post
Bumping old thread.
OEM only.
2016 NFG 1SS A8
Old 10-25-2018, 12:24 PM   #23
Deakins
Drives: 2017 2ss, m6
I haven't run OEM fluid in my diff since the first change. 33,000 miles on the clock with 30 or more tack hours with zero groan or issues. Currently running AmsOil 75w90 gear oil with no additive and no groan whatsoever. To each their own.
Deakins is offline   Reply With Quote
Old 07-13-2020, 08:47 PM   #24
bnguyen17
Drives: Chevy Camaro 2017 SS
did you need limited slip additive?
bnguyen17 is offline   Reply With Quote
Old 08-26-2020, 11:20 AM   #25
Clearly_Canadian
Clearly_Canadian's Avatar
Drives: 2017 2SS Camaro
I just did my rearend with Royal Purple Max Gear with Synerlec 75W-90.
Transmission with Royal Purple Synchromax.
2017 Camaro 2SS, K&N Air, Borla S-Type, Cat Delete, 1LE replicas, Hotchkis Swaybars, Eibach Springs. ALL BMR arms, end links, chassis braces and cradle lockout. Hurst shifter.
Clearly_Canadian is offline   Reply With Quote
Old 09-23-2020, 07:27 PM   #26
getchapull
TEXIT
getchapull's Avatar
Drives: 2019 ZL1 M6
Used Royal Purple for my diff and M6. Great stuff!
getchapull is offline   Reply With Quote
Old 09-23-2020, 08:59 PM   #27
Wilka_SS
Drives: 2016 Nightfall Metallic Grey 2ss
There is a service bulletin with this concern, the procedure basically tells dealership technicians to flush the diff with new fluid, do figure 8s and keep flushing until the noise is no longer present. I would not use any other fluid than oem even if tracking the car, they have differential coolers for a reason. The noise is caused by the clutches not being broken in or too much material suspended in the fluid. I've done this procedure personally on my own and about 4 other friends cars here locally and have never had to do a second flush. There is an additive in it for the clutches so call me crazy but I dont know anyone with differential problems using oem fluid.
Wilka_SS is offline   Reply With Quote
Old 09-25-2020, 11:34 AM   #28
KLG
KLG's Avatar
Drives: 2016 2SS Convertible
Same for me.
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
KLG is offline   Reply With Quote
