dave@hennessey
Old 05-23-2014, 02:45 PM   #1
NipTuckTaxi
NipTuckTaxi's Avatar
Drives: 2010 Camaro 1SS
Heat extraction
What has been the latest info and results on heat extraction hoods, vent inserts etc? Any problems with water ingress or other issues? Down south it gets terribly hot with the weather especially sitting still. Add headers , supercharges etc and I'm sure things made of plastics and electricals will be begging for relief. Is it worth cutting or changing hoods to provide heat extraction or best to leave it be?
NipTuckTaxi is offline   Reply With Quote
Old 05-23-2014, 02:47 PM   #2
spyderbuddy
spyderbuddy's Avatar
Drives: 2010 RS Inferno Orange Metallic
Hex Vent Or the TL1 by ACS
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
spyderbuddy is offline   Reply With Quote
Old 05-23-2014, 02:51 PM   #3
Cyber Gray
Wind Rider
Cyber Gray's Avatar
Drives: ZL1 19 White; Jeep 5.7 GC 15
Hot like what exactly ?? 128 F ??
Im not Gray any more !!
Cyber Gray is offline   Reply With Quote
Old 05-23-2014, 03:48 PM   #4
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
HOT ,you boys need to come to Phoenix in July and you will know what HOT is .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 05-24-2014, 05:11 AM   #5
Cyber Gray
Wind Rider
Cyber Gray's Avatar
You all need to come to Muscat.
It is 102 F at (Midnight) this time of the year , I will leave the day time temperature for you imagination
Old 05-24-2014, 05:38 AM   #6
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
You guys want to know what hot is go to Iraq.
OP, as far as Hex Vents go they are designed to prevent water from just pouring down on top of your engine.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs
rberns is offline   Reply With Quote
Old 05-24-2014, 06:29 AM   #7
maroman1138
maroman1138's Avatar
Drives: 2011 SS/RS LS3
Yea, but it's a dry heat.
2011 1SS/RS LS3 - Stage II Ported Heads, Stage II Comp Cam, Ported T.B., Hurst Shifter - 0BX LT Headers - CAT delete, Pype Bomb Axle-Back Exhaust - Muffler delete - 4.5 Resonated tips, Spectre CAI, - 480 RWHP 442 TRQ. Dyno tuned by ARD.
maroman1138 is offline   Reply With Quote
Old 05-24-2014, 09:39 AM   #8
Cyber Gray
Wind Rider
Cyber Gray's Avatar
It is dry but when you squeeze your under pants you find some liquid
Old 05-24-2014, 09:42 AM   #9
Cyber Gray
Wind Rider
Cyber Gray's Avatar
Come to Oman. I will take you to our rig site in the middle of the Empty Quarter Desert, and you will miss Iraq
Old 09-16-2014, 09:27 PM   #10
Ashley@HPE
Ashley@HPE's Avatar
Drives: 2010 Camaro SS, 2012 ZL1
The HEX Vents are designed for heat extraction. As you're driving, you can actually see the heat waves coming out of the hood. As for water, HEX Vents come with drip pans, that are attached to the bottom and release the water through the front end. However, the heat extraction still works very well. You do not need to use the drip pans, but if you do not want water marks under the hood, then using them is recommended. If you would like to order, we have two coupon codes available, and you can PM me for more information. Hope this helps!
Ashley@HPE is offline   Reply With Quote
Old 09-17-2014, 09:06 AM   #11
Birm
Birm's Avatar
Drives: Florida Speed & Power
Been there, Afghanistan is worse... but the humidity of Florida mid-summer takes the cake. Not many hot places I haven't been
Birm is offline   Reply With Quote
Old 09-17-2014, 09:12 AM   #12
BenningJ
BenningJ's Avatar
Drives: 2013 AGM 1SS/RS LS3
HPE HexVents FTW!
I drive my car year round and I haven't had any issues with water. You can see the heat pouring out of the vents at stoplights. I can only imagine what it would look like with the added heat from a supercharger.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts
BenningJ is offline   Reply With Quote
Old 09-17-2014, 12:53 PM   #13
Demon War Horse
War Horse Pilot
Demon War Horse's Avatar
Drives: 2017 NFG 1SS 1LE
Our 14 has the heat extractor hood stock and I can also see a really good heat mirage over the vent at stop lights. This is just in N. Texas when we get to 100 each summer, but not melt your ass hot like those that have been in Iraq or Afganistan, or any desert therefore...
Dry heat or not, I do not car to stand in a hair drier. Phoenix was nuts like that. Just oppressively hot!
COTW 09/07/2015 - 2014 AGM 2SS/RS - RIP 6/01/17
2017 Nightfall Gray Metallic 1SS 1LE Born 5/17/17 - Click Sig Pic below for for Demon War Horse 02 Build Thread
SigPic by Hazman
Demon War Horse is offline   Reply With Quote
Old 09-17-2014, 01:01 PM   #14
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS For Sale
See above, heat extractors definitely help.
But to add to the other discussion, I have also been around the world, and Southern Louisiana, on the Gulf of Mexico is the hottest of all. 105 degrees with a billion % humidity is no joke (Florida is the same story, anywhere around the Gulf/Swap).
Dry heat doesnt bother me at all, even at 110 degrees.
vroomapunk is offline   Reply With Quote
