09-13-2014, 08:50 AM | #1 |
Drives: Camaro 2Lt Join Date: Nov 2011
Water leak into passengers floor mat
So for the third time now I notice water/moisture in the passenger side carpet. The first time I thought it might have been a spilled water bottle or something, second time I just couldnt figure it out, today Noticed water on the rubber floor mat, and the rubber trim that lines the door had a few drops on it as well. Its seeping from there to the plastic trim and from there to my floor mats. Does anyone else have this problem? Any Ideas on how to fix it?
Ill post pics in a few minutes
09-13-2014, 09:10 AM | #2 |
Drives: 2SS/RS Join Date: Sep 2008
Every time I've seen and heard of this on the Camaro it has been an AC issue. The drain for the condenser is most likely clogged.
09-13-2014, 09:17 AM | #3 |
Thanks for the suggestion Mr_Draco, Ill check that out next, I also think it might be due to rain, but all the trim seems intact, except for the part under the door which had a few drops in it
09-13-2014, 09:31 AM | #4 |
Drives: 2012 1SS, 6spd. many mods 478 rwhp Join Date: Apr 2014
Not saying it's the drain for sure, but a clogged drain will allow rain water that runs in at the air intake (on the cowl by the wipers) to back up and run into the interior just like the a/c condensation would. Had an old Cavalier with a foot of water on the floor because of that.
09-13-2014, 10:24 AM | #5 |
Drives: 2011 Camaro SS Join Date: Mar 2014
They are correct, 9 times out of 10 its the drain for the ac condensation. Always leaks on the pass side floor board. Check to make sure its actually water and not coolant. If it's coolant, its a heater core. And thats a bitch. AC drain, not so much.
09-13-2014, 10:40 AM | #6 |
Drives: '14 1le Join Date: Jan 2014
If there are tree leaves in the cowl area just under the pass side hood, could that be the problem?
You should check that also. |
09-13-2014, 10:52 AM | #7 |
Would rather be riding
Drives: No car no more Join Date: Jul 2009
I hope your heater core isn't leaking.
No dog in this fight anymore.
5th Gen owner 2009-2016. |
09-13-2014, 10:54 AM | #8 |
Drives: 2014 2SS RS Coupe Join Date: Aug 2013
On my silverado water used to come into the passenger side each time it rained, the heater core is very easy to pull out because it's right up front, it was clogged with leaves and shit like that.
09-13-2014, 11:05 AM | #9 | |
Don't confuse people, we are talking about Camaros, the heater cores are not easy to change in these cars.
09-13-2014, 12:27 PM | #10 |
Drives: 2014 Camaro 2LT Join Date: Sep 2014
09-13-2014, 12:34 PM | #11 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Remove your cabin air filter and clean out the air intake.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
09-13-2014, 06:19 PM | #12 | |
Drives: 2011 1LT Join Date: Mar 2012
If the heater core in my Sliverado goes out again, I will find something else to do other than fix it. Sell it, trade it, or set it on fire and roll it off a cliff. I am NOT going to try fixing that again. Back on topic, sort of: I HEAR the the heater core in a Camaro is similar in aintitabitchiveness. |
09-13-2014, 06:34 PM | #13 |
I checked under the glove box, everything is dry there. Then i checked the cabin air filter, its fine and completely free of debris. It rained again so afterwards I went to check on the trim, sure enough there was water on it, it turns out it was due to some damage done a couple months back when they broke into my car. It got fixed but apparently they did not tuck in the trim all the way and it was causing water to leak onto the side of the door that comes into contact with the rubber. I popped it back in place and ill check again tomorrow.
09-13-2014, 09:02 PM | #14 | |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
