03-30-2014, 01:54 AM | #1 |
Drives: 2014 Camaro RS/2SS 1LE Join Date: Nov 2013
Weird Thing Happened to Audio/Nav System
Something weird happened while just driving along... The audio/navigation system just went completely black. It was working fine one minute and just completely went black the next minute and would not come back on. I was on my way to a grocery store, so I shut the car off when I got there and waited about 3 or minutes and started it again. The audio/nav system was still out, so I called my dealership as I was walking into the store. They said they'd never heard of this happening, so I made an appointment to take it in the next day. After about 30 minutes in the store, I returned to my car and started it up and the audio/nav system was working again.
Anyone else had this happen? |
03-30-2014, 06:15 AM | #2 |
Drives: 2013 2SS 1LE Join Date: Jul 2012
I had that happen while I was at the dealership once. The service manager did a disconnect;waited 30 seconds, and reconnected the battery and the radio started working again. I was then told it is because the amp will sometimes get hot and cause this problem.
03-30-2014, 05:19 PM | #3 |
Drives: 2014 2SS/RS Camaro 1LE Join Date: Mar 2014
I was driving and started to get a little hot, went to turn my air condition on, and to my surprise nothing was working. Heated seat, would not work as well. My audio and nav was working but any of the controls that function the air or heater did not work. When I arrived home, and I shut it off and waited and turned it back on and still did not work. I called made an apt, and put the car up for the night, to my surprise it started fine the next morning. The dealership said they could not troubleshoot it cause it was working fine. It has not happened since, so just keep an eye for it. Hopefully it was just a glitch and you wont have no serious problems, but its under warranty anyways. Good luck.
03-30-2014, 06:16 PM | #4 |
HTCC Member
Happened to me and dealership allegedly did a software update, still happened to me 2 more times after the update. Its been 5 months and so far no more problems.
03-30-2014, 07:27 PM | #5 |
Remember the Charleston 9
Drives: 2004 KME PREDATOR, 2014 2SS/RS/1LE Join Date: Nov 2008
Never had a problem with mine. I'm at 4600 miles.
2002 V-6 5 speed rally red (current camaro) Also driven:1992 Z-28 305 auto Red w/ black stripes (anniversary), 2001 V-6 auto light pewter metallic,1991 RS V-6 auto Black |
04-07-2014, 01:07 AM | #6 |
Audio system also "freezes" up a lot when connected to my iPhone... Happens regardless of whether listening to music through Bluetooth or when connected via USB port. I get the message, "Audio Paused". After a minute or so, it'll start playing again; other times, I have to manually press "Play".
Really annoyed with audio/navigation system issues! |
04-07-2014, 05:58 AM | #7 | |
Drives: Black 14 2SS/1LE/RS 14 Tundra Join Date: Dec 2013
04-07-2014, 10:02 PM | #8 | |
Drives: 2014 Camaro 2SS 1LE Join Date: Nov 2013
04-07-2014, 11:11 PM | #9 |
Resident Artichoke
Drives: 14 1LE, 97 Z28, 07 Z06, 67 Chev SS Join Date: Dec 2013
Just happened to me today. I was playing tunes from my iPhone through bluetooth and the fan/AC would not come on. After a minute or so, it finally kicked on. Weird.
2014 Camaro SS 1LE, 2016 Z06 Corvette, 1997 Camaro Z28, 1967 Chevelle SS
04-08-2014, 10:05 AM | #10 |
Drives: 1969 Z28, 1982 Z28, 2014 SS/RS/1LE Join Date: Nov 2013
Sounds like an overheating issue. GM will have to look into that! With all the electronics running, a LOT of heat is generated and if tightly packed in the dash without any air circulation, they are going to have overheating problems.
04-08-2014, 10:06 AM | #11 |
The girl with the 2 Danes
Drives: 2014 2SS/RS LS3 Join Date: Oct 2013
mind did this the other day... I took a photo..
also had issues with the comfort dials.. I am turn the air up and it shows off on the display... :inono:
04-08-2014, 10:07 AM | #12 |
I had it happen once after I had it cranked for 15 min. I think the amp gets hot.
Drives,
2016 Camaro 2 SS, (OLD CAR)2014 Camaro 1LE, 2SS, NPP Dual Mode Exhaust, K&N Air Filter. E3 Catch Can. z28 Grill, and 1LE Badging |
04-08-2014, 11:08 AM | #13 |
Drives: 2014 Blk 2SS/1LE Join Date: Jul 2013
Once in awhile the radio will go to AUX without me touching anything. After a few seconds it bounces back and forth then its fine
04-09-2014, 06:20 AM | #14 |
Drives: 2014 Summit White 2SS Camaro 1LE/RS Join Date: Jan 2014
Couple of days ago I tried to turn on my AC but nothing would happen, it would just display at 0. After trying about 8 times it finally kicked in. Couple hours later I was driving home and it decided to turn my volume from 16 to 24 by it self. Just got back from a furneral, wonder if my Grandmother is messing with me.
