02-16-2014, 10:56 AM | #1 |
Considering No-Hole Plate Frame? This is PERFECT!!
Got my front license plate frame from JacFab - fit like a glove! Looks great and is extremely sturdy. Installing only took about 5 minutes and all the frame lines lined up perfectly with the lines on the car. Thanks Jason - this frame is amazing!
02-16-2014, 11:02 AM | #2 |
Drives: Cool parts for cool cars Join Date: Sep 2009
This is a nice touch if you need a front plate. Like the way its Vee'ed in the middle.
Can you show us some other views of it? |
02-16-2014, 12:58 PM | #3 |
More Pics
Last one is how I bent plate...measured plate to center, marked both top & bottom of plate. Centered marks & clamped it to finished 2x2, used palm to slowly apply pressure. Flipped license plate, centered & reclamped on 2x2 and added pressure to other side of plate.
02-17-2014, 08:03 PM | #4 |
Drives: 14 1SS Camaro 1LE, NPP, Recaros Join Date: Nov 2013
cops will hate it, no flat surface to aim radar at.
02-17-2014, 08:48 PM | #5 |
i wish i knew about this sooner! :-(
Follow Me @ssatann_ss |
02-17-2014, 10:28 PM | #6 |
Drives: Camaro Join Date: Sep 2013
02-17-2014, 11:51 PM | #7 |
02-18-2014, 11:54 PM | #8 | |
19 states don't even require front plates and I'm sure the cops have no issues radaring there Those license plate covers you speak of probably are a non-reflective cover |
05-26-2014, 02:42 AM | #9 | |
Drives: 2014 1LT RS Join Date: Nov 2010
12-01-2014, 02:27 PM | #10 |
Uhhh, sorry for the REALLY delayed response. I suppose it should have said turned plate 180 degrees and applied pressure...not "flipped" - I turned 180 to apply even amount of pressure to each side to make sure it was as evenly "bent" as possible,
