Vararam
Old 08-17-2013, 10:56 AM   #1
retro500
retro500's Avatar
Drives: 2013 Camaro 2SS Black L99
Help K&N Intake Install....piece unknown 2013 Camaro
Hey everyone. I just got my K&N air intake delivered part #63-3074. I pretty much know how to install. I had a 2011 and did a CAI install myself. Now I have a 2013 SS. Anyways I was looking at my stock intake and the bolt on the right side of intake has this grey piece attached to it, holding a wire that's attached to the side of the metal.I have never seen this before on my previous 2011. What is it and how do I remove it so I can get the stock intake off? Please help, I don't want to damage anything. Here's a picture of what it looks like. Thanks in advance.
retro500 is offline   Reply With Quote
Old 08-17-2013, 11:39 AM   #2
LS3 SS
LS3 SS's Avatar
Drives: 2010 Cyber Grey Camaro SS (LS3)
Look on the sides of it to see if it has any sort of "teeth" or clip design where you have to use a flat tip screwdriver to separate it. Other than that, try twisting and pulling, but be careful.
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
LS3 SS is offline   Reply With Quote
Old 08-17-2013, 12:41 PM   #3
retro500
retro500's Avatar
Thank you. But what is it for and what is the wire? Thanks
Old 08-17-2013, 01:13 PM   #4
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
It's just a wire retainer. You can slip something slotted under it and it should pry/pop off. I'm not familure with the K&N intake, but after you mount it, if the stud is still accessible, just push the retainer back on the stud. If not, your not going to hurt anything by leaving it off. I'm not sure what the wire is for, but it might be the hood release cable.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 08-17-2013, 01:15 PM   #5
retro500
retro500's Avatar
Ok sounds good. I'm out to lunch with the wife. Then I'm going to tackle the job. I'll let you guys know. Thanks a lot for the help!!!
Old 08-17-2013, 01:20 PM   #6
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
That wasn't on my '12 either.
Another 1 of 371 '12 T3 LS3 M6's built.
Iam Broke is offline   Reply With Quote
Old 08-18-2013, 09:13 AM   #7
retro500
retro500's Avatar
Update: Freshly Installed K&N Intake
