TireRack
Old 06-19-2015, 10:18 PM   #1
kiwijohn
kiwijohn's Avatar
Drives: 2010 camaro
Want 1000hp
what other upgrades can i do to my engine .ive got a magnuson supercharger installed what more do i need to do .cam, head work any help will be appreciated
kiwijohn is offline   Reply With Quote
Old 06-19-2015, 10:29 PM   #2
AGP Turbo
Drives: All things Turbocharged
You need all your parts to be able to handle 1000hp first. So that's going to take a forged motor, while you're doing that you may as well stroke it to 416ci. Then everything after the motor will need to handle it too. Then you just need a way to push 1000hp worth of air into that motor. Your supercharger can't, so you could add nitrous or just upgrade the supercharger to a larger centrifugal unit. Or our twin turbo kit has no problem supplying that airflow. And then you just need 1000hp of fuel flow and get it all tuned to work together.
AGP Turbo is offline   Reply With Quote
Old 06-19-2015, 10:53 PM   #3
Detoxx03
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Detoxx03's Avatar
Drives: 2008 Corvette
Take maggie off and install twins along with forge a shortblock.
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 06-19-2015, 11:43 PM   #4
bct10985
Drives: 2010 2SS LS3, 2013 duramax
A lot of money
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 06-20-2015, 07:28 AM   #5
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
I guess 1000 is the new 500. The internet makes it sound easy so everyone wants it now. LOL.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000,
realcanuk is offline   Reply With Quote
Old 06-20-2015, 08:27 AM   #6
'14-ELLIE
'14-ELLIE's Avatar
Drives: 2015 2SS/RS 1LE
How I consider LS3 Upgrade costs...
450 RWHP - $
500-600 RWHP - $$$
600-800 RWHP - $$$$$$$
801 RWHP - LOTTERY
Remember, that much power doesn't just affect the engine.... Suspension, clutch, fuel, and a whole lot more needs upgrades at the same time.
'14-ELLIE is offline   Reply With Quote
Old 06-20-2015, 09:01 AM   #7
Unreal
Drives: 2006 Z06
Disageee.
800rwhp AGP kit for $7500
900rwhp AGP kit with fuel for $8500
1000rwhp add forged motor/etc
AGP has done a bunch of bone stock 1LEs, they come in with <2k miles, leave with 790-810rwhp.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 06-20-2015, 09:19 AM   #8
Slowhawk
Drives: 1999 Trans Am
1000hp on the dyno is different than 1000hp on the street,that lasts.
A good forged motor,fuel system,tranny, A FI kit that can supply enough air.
Slowhawk is offline   Reply With Quote
Old 06-20-2015, 02:25 PM   #9
'14-ELLIE
'14-ELLIE's Avatar
Originally Posted by Unreal View Post
Disageee.
That's fine to disagree. I'm pushing the same and with a different TT setup. If I had an AGP kit, I'd have the same opinion. Power and safe power are two different things. If you want 800+, you better be looking further than just the motor. Other components of the car need some attention too.
Old 06-20-2015, 02:32 PM   #10
Ret Fuzz
Drives: 2010 Camaro
OMG does every post here have to turn into an AGP Commercial?
LOL.... 8500 dollars.... and about 10 g worth of damage.... Motor ... tranny and rear.... But Hey the motor made 900
So much for responsible project builds.
Ret Fuzz is offline   Reply With Quote
Old 06-20-2015, 02:38 PM   #11
'14-ELLIE
'14-ELLIE's Avatar
Thank you... Everyone is thinking it. You said it! Hope he gets commission!
Old 06-20-2015, 02:52 PM   #12
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Disageee.
800rwhp AGP kit for $5400
Fixed it. The kits are on sale now.
1000hp on the street is much cooler in conversation than reality. It isn't as much fun as you'd think when the rear is sliding around as if it is on ice. All I can think is "Tires, I'm going to need tires soon."
Old 06-20-2015, 03:43 PM   #13
LuckyZL-1
Ragtop Rocket!!!
LuckyZL-1's Avatar
Drives: Black on Black Convertible
The guy did say you need everything after the motor once you make the 1000hp. The OP asked a question and in my opinion got a damn good answer.
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package.
744rwhp 727rwtq
LuckyZL-1 is offline   Reply With Quote
Old 06-20-2015, 04:10 PM   #14
realcanuk
realcanuk's Avatar
As Slowhawk said, there is a difference in making 1000, or making 1000 that is reliable and lasts.
To do 1000 that is reliable costs big money. Anyone that says it doesn't probably hasn't done it. It can be done on the cheap, but it wont last and wont be reliable. If you add up 1000hp capable blower or turbo system, built engine, fuel system, tranny and diff upgrades, wheels and tires, and thousands in misc stuff, it gets expensive fast. Every area that you save by not making it compatible, will cost you aggravation and money a bit later.
