07-14-2017, 11:10 AM | #1 |
Drives: 2011 Chevrolet Camaro SS Join Date: Jul 2017
Texas speed headers???
Im in the process of looking for a good set of LT headers for my 2011 camaro SS LS3. I know kooks and ARH are good reputable brands. But a friend of mine suggested Texas speed LTs. After doing research im getting mixed views. Some saying they fit great and other saying fitment is sometimes off.
07-14-2017, 11:11 AM | #2 |
Drives: 2011 2SS Join Date: Mar 2015
I've heard very very few bad reviews about Texas speed headers. There are a ton of members here running them. There are dozens of great threads with fantastic reviews of them (as well as other headers worth considering)
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears |
07-14-2017, 12:02 PM | #3 |
Yea it seems strange alot of ppl are running them but yet i see so many bad reviews.... the price is not bad at all tho. Just not trying to avoid customer service problems if they do not fit
07-14-2017, 01:35 PM | #4 |
Drives: 18 2SS LT4 Top Join Date: Jan 2014
i run em ..great headers ! wouldnt buy any others imo
07-14-2017, 02:15 PM | #5 |
Started#gottalovethatblue
Personally I was going to go with them until the last second I went with Kooks. They are good headers and you should get good use out of them. They're Chinese made, so they may not have quite the build quality of Kooks/ARH/Stainless Works, but they are good headers and should serve you well. I think unless you're going with the 2" pipes you shouldn't have much fitment issue and many people have said that they have been working to fix that fitment issue as well. Good luck and happy modding!
07-14-2017, 02:33 PM | #6 |
USA-1
Could always run Speed Engineering for $350...
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
07-14-2017, 02:44 PM | #7 |
My TSP headers fit like a glove. Only thing I don't like about them is the 'Slip-Fit' style collector flanges. But other brands use those as well, such as Speed Engineering.
They also claim to have some of the thickest steel tubing you can get, at 2mm. Supposedly thicker than most competitor's, according to TSP...."2.0 mm thick tubing (much thicker than competitors' headers)" I would buy mine again in a second. BUT, if I truly had to do it again, I would spend more and get either Doug Thorley Tri-Ys or Kooks Stepped headers.
07-14-2017, 03:14 PM | #8 |
Thanksi appreciate the help. I am new to the forum and ls world. I am open to any suggestions and tips when it comes to hp gains etc.
2011 camaro 2SS LS3
Airaid CAI, GMPP exhaust... more bolt-ons coming soon! |
07-14-2017, 05:11 PM | #9 |
USA-1
Are you running 3.91 gears?
07-14-2017, 05:31 PM | #10 |
Stock gears. I am also looking for a set of rear rims for 10" wide nittos
2011 camaro 2SS LS3
07-14-2017, 05:35 PM | #11 |
Drives: 2012 M6 Camaro SS (RIP) Join Date: Nov 2014
Never heard a negative thing about Texas Speed anything
Speed engineering 1 7/8 LTs, CAI inc Cold Air Intake, offroad connectors, Solo performance axle back with J pipes, tune, and in need of a driver mod LOL
07-14-2017, 05:42 PM | #12 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
Not to jack the thread but im also looking at some long tubes. My concern is the longevity of the cats....Im in Canada so price will surely be a sticking point as well as quality. Are the cats listed for the headers mentioned good quality. I can get BBK 1 7/8 ceramic coated longtubes with cats for $1400 taxes in but im just not sure about their quality.
07-14-2017, 07:14 PM | #13 |
Not with cats. If you're getting cats the cost is very similar.
07-15-2017, 03:35 AM | #14 |
USA-1
Yep, never said anything about them having cats. Who runs those things anyway?
Tags |
arh amercian racing headers, headers, kook header exhaust, ls3 header, tsp |
