06-12-2014, 10:19 PM | #1 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
1LE PVC System on LFX
Can you install a 1LE PVC System on a LFX motor?
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
06-12-2014, 10:26 PM | #2 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
Yes, there is a thread about it in the DIY section... Or it might be in this section, but it's been done...
http://www.camaro5.com/forums/showth...hlight=1le+lfx But why would you want to? You can buy an aftermarket clean side can for quite a bit less than the 1LE one. |
06-13-2014, 06:46 AM | #3 |
Get the Elite.
'Nuff said. |
06-13-2014, 09:37 AM | #4 |
Drives: '12 2LT Convertible Join Date: Mar 2012
I have done this (as you can see from the DIY thread Jason posted).
If I was to do this today, I'd probably start with the new Elite clean side separator for cost reasons. I probably would not buy another catch can. For the the way I drive the LFX, that would be overkill. Also do not be too put off by the price of the 1LE Oil Separator. It can be had for less than MSRP if you know where to look.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
06-13-2014, 09:53 AM | #5 |
Drives: 2010 Camaro Join Date: Nov 2009
06-13-2014, 01:48 PM | #6 |
KaBoom1701
Can i get some credit on my rx can......lol
I love to trade up if you can work a deal.
Mods:
06-13-2014, 02:10 PM | #7 |
Go sell it over on the modern camaros forum. AFTER you get your Elite.
06-13-2014, 05:14 PM | #8 |
KaBoom1701
Lol. K
Mods:
06-13-2014, 10:00 PM | #9 |
Go Gators!
Drives: Camaro Jeep Abarth 944 325i Join Date: Jan 2013
Is there a way to simply use a normal catch can setup on the clean side as well?
'13 Camaro, '97 Wrangler, '12 500 Abarth, '85.5 944, '06 325i
Suspension Mods: BMR and JPSS Sways, BMR Poly Bushings, BMR strut tower brace, BMR control arms, BMR toe arms, stock springs and struts Engine Mods: All bolt ons (haha) Brake Mods: Brembo SS caliper swap front and rear |
06-14-2014, 05:35 AM | #10 |
Drives: 2012 v6 camaro Join Date: May 2014
Why cant we just use the universal catch cans on ebay that cost like 30.00 ? Im not saying the elite isn't good quality< I just don't understand the difference. If I can save money nfor more parts that's what I would like to do.
06-14-2014, 05:40 AM | #11 |
most of us tend to buy what we know works properly. if you buy the cheap one and it does not work then you will still end up buying the better one you should have bought in the first place and in the end spending more money. do it right the first time, go with what is known to work well.
06-14-2014, 09:38 AM | #12 | |
KaBoom1701
This. +1
Mods:
06-14-2014, 11:32 PM | #13 |
Drives: 2010 Camaro IBM 2LT/RS M6 Join Date: Sep 2009
Because most of those cans are empty and have no baffling inside for the oil to condense onto when it travels through the catch can. So the oil just flows right though as if you had no catch can at all, defeating the purpose of having one in the first place.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade. |
