06-25-2013, 05:12 PM | #15 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
Lol
or keep it in 1st gear and never shift it unless necessary lol.
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
06-25-2013, 05:33 PM | #16 |
Drives: '13 camaro zl1 '08 daytona charger Join Date: Dec 2012
06-25-2013, 05:34 PM | #17 |
Why am I only getting 2mpg?!?
06-25-2013, 05:34 PM | #18 |
Drives: nothing Join Date: Nov 2010
really?
06-25-2013, 05:55 PM | #19 |
Drives: 2015 Z/28 #533 Join Date: Jul 2012
06-25-2013, 05:57 PM | #20 |
Drives: 2010 2SSRS headers/CAI/tune/corsa, Join Date: May 2010
I love mine not to loud at idle but your ears will bleed at WOT.
Now I which cold start was not that loud or I should say the neighbors . 5:30 AM
Stainless works headers/cats Roto fab CAI /
Corsa install and tune Livernois TSW Nuburgring 9 &10" x 20 on Invos (315 & 275 ) JL Audio XD400/4 amp Pfadt trailing arms & tie rods sway bars. pedders street 1 package. ,Hurst short throw shifter With bronze bushings . |
06-25-2013, 06:01 PM | #21 |
Stroked and blown
I see the op is an automatic. That's even better because he won't have to use the handbrake. Slip it into neutral and stay on the gas. FTMFW
LME 416 LS3 shortblock/Callies Compstar 4340 4"crank/Callies 6.125 H beams rods/Wiesco 4.07 forged pistons/Cam Motion custom LS1/LME ported heads /maggie TVS2300/I West 8rib 10%OD /3.2 pulley/OD cog drive/JRE tensioner/ID850 /ADM dual fuel/Kooks LT 1 7/8/magna flow2.5 /cat delete/Roto Fab CAI /MGW short throw /SPEC super twin clutch/G Force built trans,carbon syncro rear shaft upgrade /DSS 9"single CF DS /Strange 3.70/31 spline trutrac/MT DR's/earls oil cooler /tuned KHC
06-25-2013, 07:16 PM | #22 |
Geek
OP. Cutouts.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1 x = ~x |
06-25-2013, 07:17 PM | #23 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Whistle tips FTW. You'll hear it ALL the time.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
06-25-2013, 07:28 PM | #24 |
Geek
It goes "Woop Wooooop!" You know what i'm sayin?
06-26-2013, 10:55 AM | #25 |
Drives: 2013 2SS Join Date: Aug 2012
You have a 2013. Do you have the dual exhaust mode? If so, those annoying little flaps control how loud your exhaust is at times.
It takes 5 mins to do the fuse pull to always keep them open.
06-26-2013, 02:59 PM | #26 |
Drives: 2010 Camaro 2SS/RS White S/C Join Date: Aug 2010
Ohhhhhhhhh so that's what it is, when I put the car in the "D" it goes forward.......
"It does not matter if you win or loose, what matters is if I win" Carl Fogarty |
03-03-2024, 08:42 AM | #27 |
Drives: 2021 Camero ZL1 Join Date: Mar 2023
I have a 21 ZL1 manual.
Mods AR Headers RotoFab Corsa Exhaust Lower pulley When I start the car, it’s loud, going thru the gears, sounds great, but once I get into 4th gear, the sound goes silent, is this normal? |
03-05-2024, 08:25 PM | #28 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
I'm waiting for Rod Serling to post on this thread.
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
