Old 11-18-2016, 02:35 AM   #1
houtx
Drives: 2011 Camaro 2SS
What do I need for a reliable cam setup?
The engine will be coming apart as I believe I have bad piston ring. Since it will be coming apart I plan on putting cam in. Now my question is to make a reliable cam setup what should I be upgrading? Car will be daily driven and currently has 70k miles. 2011 SS LS3 M6
houtx is offline   Reply With Quote
Old 11-18-2016, 02:42 AM   #2
Gunmetal Speedster
Gunmetal Speedster's Avatar
Drives: Savitar; The 500rwhp N/A Monster!
I asked this same question, and I was told all of this.
Website is currently down it seems, but when it gets fixed that link should take you to a camshaft kit.
*SOLD*504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
Gunmetal Speedster is offline   Reply With Quote
Old 11-18-2016, 02:51 AM   #3
houtx
Thanks. Yes it looks down to me too. I will keep checking.
Old 11-18-2016, 02:54 AM   #4
Sapper12b
HTCC Member
Sapper12b's Avatar
Drives: 2013 Camaro SS
I got my cam installed at 75k miles and this is what I used. Plus I had a new timing chain added along with a milling pump. Since you are in Houston we can meet up and talk, I can show you my build sheet.
http://www.briantooleyracing.com/bundle-cam-kit.html
Here is a link to my build thread, most of what I had installed is listed there.
http://www.camaro5.com/forums/showth...=275478&page=7
Sapper12b is offline   Reply With Quote
Old 11-18-2016, 03:51 AM   #5
2010reddevil
Drives: 2010 Camaro 2SS Victory Red 6M
A good cam swap will cost you about 1800 in parts alone if you do it right. That is including a new cam. Like the old saying goes, cheap, fast and reliable. Pick 2 and go from there.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19
Gone on 12/28/19 R I P
2010 2SS 6M Victory Red/Black (old ride)
CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back.
12.6 @ 115 SAR as of 9/19/15
Gone but never forgotten.
2010reddevil is offline   Reply With Quote
Old 11-18-2016, 04:16 AM   #6
charles71
charles71's Avatar
Drives: 2011 Camaro SS
Springs, lifters, seals, retainers/locks and pushrods dependent on cam size and just to be safe high volume oil pump.
Livernois Stage II Heads & Cam, LS7 Lifters, Ported Intake & Throttle Body, Rotofab CAI, BBK High Flow Fuel Rail @ Guage, Eaton Tru Trac Posi with 3.91 gears, 1000 HP Axels, Kooks Long tubes & full Corsa Exhaust, GM Hurst Short Throw Shifter, Mcleod RXT Twin Disc, Vitesse Throttle Controller, 1.5" Lowering Springs, Strut Tower Brace, SLP 25% Underdrive Pulley, Apex reservoir relocation kit and air scoop.
charles71 is offline   Reply With Quote
Old 11-18-2016, 07:09 AM   #7
camaro34
camaro34's Avatar
Things to replace: Lifters, springs, retainers, locks, and seals. Things to check: push rod length (lifters should have about 3/4 turn preload), piston to valve (about .080 intake and .110 minimum exhaust) and the oil pump (check for signs of wear). If the pump is good it does not need to be replaced, if the pump is bad I would replace it with a factory LSA pump. Most pump failures are because of three reasons. First the o ring in the pickup tube is not installed correctly and does not seal. Second the pump is not clearenced correctly. Third there is a failure else where in the engine and the pump picks up the debris. We have built several LS engines and the only time we run a milling pump is on an engine that makes 1000+ hp.
Hope this helps and good luck
camaro34 is offline   Reply With Quote
Old 11-18-2016, 06:46 PM   #8
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Vengeance racing has complete cam kits. They are around $1300
Includes all items listed below
Vengeance Racing Custom Camshaft of Your Choice
Vengeance Racing 5/16" Hardened Pushrods
Vengeance Racing .660" Lift Dual Valve Spring Kit
C5R Timing Chain
Melling Hi Volume Oil Pump
Comp Cams Trunion Upgrade
GM Front Cover Seal
GM Front Cover Gasket
GM Waterpump Gasket Set
GM Crank Bolt
ARP Cam Bolts
LS7 Timing Gear
LS2 Dogbone Timing Damper
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 11-18-2016, 09:03 PM   #9
houtx
Question
How do i know which length of rod to get?
Old 11-19-2016, 12:19 AM   #10
houtx
KATECH C5-R TIMING CHAIN FOR GEN III/IV LSX HME-G68V-2
MELLING STANDARD VOLUME, HIGH PRESSURE OIL PUMP MEL-10295
CHEVROLET PERFORMANCE LS2 LS3 LS7 TIMING CHAIN DAMPENER 12588670
1 x BTR LS3 N/A STAGE IV 3 BOLT CAM $0.00
1 x .660" LIFT PLATINUM SPRING KIT WITH TITANIUM RETAINERS $50.00
1 x BTR 7.350" LONG, 5/16" DIAMETER, .080" WALL CHROMOLY ONE PIECE PUSHRODS; SET OF 16 $0.00
What do you guys think I am missing?
Is the spring good or should I stick with steel?
Are the pushrods correct size?
Old 11-19-2016, 09:02 AM   #11
jc615
jc615's Avatar
Drives: Camaro and Sierra
Question
Measure if you want to do it properly. Most will come with a standard size that should work if you havnt milled heads or anything extreme
jc615 is offline   Reply With Quote
