TireRack
Old 04-14-2016, 03:45 PM   #1
hcoll003
Proven Wicked Suspension
hcoll003's Avatar
Drives: 2010 Camaro 2SS/RS
FE3 Pfadt sport sway bars or FE4 Stock 1le sway bars???
I have a 2010 Camaro SS with PFADT Sport Sway bars on the original FE3 suspension. If I upgrade to the FE4 suspension with the updated FE4 control arms and install stock 1le sway bars do you guys think my car will handle better or would it be a downgrade unless I get aftermarket sway bars?
Thanks
hcoll003 is offline   Reply With Quote
Old 04-14-2016, 05:39 PM   #2
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
One of the things that will impact the response you are looking for is what wheel/tire setup you are using. The 1LE setup is geared towards a square wheel/tire combo whereas the stock SS uses staggered.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 04-24-2016, 08:23 PM   #3
hcoll003
hcoll003's Avatar
I have a square setup on my car. 20x10 on all four corners.
