03-21-2016, 11:54 AM | #1 |
Drives: 2015 Camaro SS - White Summit Join Date: Mar 2016
Suspension and Tire Recommendations?
I am in the process of looking at suspensions systems for my 2015 Camaro SS. was mainly looking at Eibach, but does anyone have any other recommendations. Looking for a 1" to 1.25" drop.
In addition to the springs, I also wanted to get new shocks (naturally) and was considering just bundling the Eibach Dampers with the springs. Also am looking for tire recommendations. I haven't picked rims out yet, looking for a more specific cost reference though. Looking for any recommendations or insight? |
03-21-2016, 11:58 AM | #2 |
Drives: 2015 1LS Red V6 Join Date: Aug 2015
If you look at this sub forum...its all about recommendations-I would take a few minutes to scroll through it. Everything you want to know, and more, is answered.
Sponsors:
Overkill Motorsport BCS Auto JacFab Machining APDEG Dream Gear Mobile Audio Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet 5th Gen V6 Performance Facebook Group |
03-21-2016, 12:35 PM | #3 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
The biggest question you will have to ask yourself is "what do you want your car to be able to do?" Because that will tell us what we need to know to make suggestions.
Recommendations for a year-round daily driver are obviously significantly different than a drag-strip only build or a SEMA show-only car. If you're looking at just some minor/simple upgrades to a semi-daily driver that can see some periodic "spirited driving", you would only really need to look at springs and sway bars. For overall ride quality with a 1" drop, I've heard the Hotchkiss are the top choices. From personal experience, my SS shocks with some ZL1 springs work really well paired up with some Pfadt sport sway bars. For tires, the question is really important because the tires I recommend for my use (year round daily driver + some snow = Continental Extreme Contact DWS) I would not take to the track. I really don't have any experience with other tires besides the stock Pirellis which I think suck for my situation. You can only go up from there depending on your goals, dreams, and expectations...
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
03-21-2016, 01:48 PM | #4 |
Thanks for the recommendations. Yes, this is my daily driver and do not care for the track. As you said, looking for improvement on handling for "spirited driving." I will check into Hotchkiss, I haven only been looking at Eibach as the prices seemed reasonable.
03-21-2016, 05:14 PM | #5 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Agreed. Do some more research. Sways will give the biggest handling improvement. Your shock/struts are pretty good factory products.....I wouldn't mess with them. Lowering springs will really harsh your ride....so be prepared. Good luck.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
03-22-2016, 05:37 PM | #6 |
drinks virgil's
Drives: 2010 2SS M6 Join Date: Feb 2014
I added Eibach sways first and the BMR 1" springs. I was worried about the springs and the ride.
I love it so much more now. Ride is much, MUCH better.
2010 2SS/RS M6 - CAI Intake - Borla Stinger - VTC - 3.91's
Eibach Sways - LG ZR28's - BMR Springs - 285/35 Squared |
03-24-2016, 11:32 AM | #7 | |
Drives: Race Car Join Date: Sep 2009
American made, Guaranteed for Life against Sag and Priced right! |
03-24-2016, 06:43 PM | #8 |
Any reason to go with BMR over Eibach? or just price? I guess they are just springs, not sure how the quality would differ?
03-25-2016, 11:50 AM | #9 |
I do not like to bash Competitors products, so I will just say ours will Not Sag! and they are priced better!
03-25-2016, 08:08 PM | #10 | |
drinks virgil's
FWIW - their 1" drop springs are perfect; exactly 1".
03-25-2016, 09:52 PM | #11 |
Zl1 rear sway bar #22786260 and leave your stock front sway. I installed 1" hotchkis springs and I'm happy with them, wouldn't want it any lower. 20x10 front and 20x11 rear wheels are popular on these cars. 285 35 20 pss are very popular tires also.
03-26-2016, 05:05 PM | #12 |
SS
Have you looked at coil overs as an option?
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
03-28-2016, 11:22 AM | #13 |
03-28-2016, 11:26 AM | #14 |
Drives: 2010 Camaro SGM 1LT M6 Join Date: Jan 2015
I have the BMR 1.2" drop springs and they are the perfect amount of drop without sacrificing clearance. No sagging either and an equal drop on all four corners.
Arkentect's Build Thread!! - UPSTATE C5 MEMBER
2010 SGM M6 1LT - SOLD Current - 2009 C6 Corvette Z51 |
Tags |
eibach suspension wheels springs |
