01-31-2013, 09:29 AM | #1 |
Strut Tower Brace
how many of you guys have a strut tower brace? i have been thinking about getting one, really like the looks of the ZL1 brace.
what would you recommend, how difficult / easy was it to install? pics if you can. thanks in advance Lupe
01-31-2013, 09:32 AM | #2 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
If you have a 2010, you will be stuck using the BMR because the Chevy one won't work.
01-31-2013, 09:58 AM | #3 |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
Same is true for some early '11s....Couldn't tell you where they come from, but I think an adaptor kit of shims, spacers, what-not is out there so the factory brace can be used on the first version of the towers...
01-31-2013, 09:59 AM | #4 | |
Drives: 2010 Camaro LS V6 Join Date: Jul 2010
C-LO or Sonic
"Without Struggle there is no progress" I am your best nightmare! |
01-31-2013, 10:05 AM | #5 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
There is an adapter kit out there which lets you use the convertible/ZL1 strut brace on 2010 or early 2011 Camaro's.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
01-31-2013, 10:06 AM | #6 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
I recommend it. It does make the car chassis stiffer, which is why you see it on the 1LEs and ZL1s. Creaking eliminated when turning into driveways and other off camber stuff.
You need to buy the tower brace and the bolts. The torque spec is: 22 N-m (16 ft-lbs). 10 minute install. Install on flat ground. |
01-31-2013, 10:09 AM | #7 |
Drives: 2013 2LT Convertible Join Date: Dec 2012
You could buy a convertible, and the brace will come standard
01-31-2013, 10:19 AM | #8 |
SYBIL
Drives: 2013 2SS/RS, silver ice metallic Join Date: Oct 2012
the 2013 has the holes pre-drilled for the brace, it only took me like 3 minutes to install it. its a noticable difference when cornering and taking curves. plus it looks badass
01-31-2013, 10:22 AM | #9 |
that looks really nice wray. i have a 10 so probably will have to drill the holes.
01-31-2013, 10:23 AM | #10 | ||
Drives: Race Car Join Date: Sep 2009
BMR two point strut tower brace (STB013) BMR four point strut towe brace (STB014) BMR four point strut tower brace (STB016) |
01-31-2013, 11:31 AM | #11 |
Drives: Chevys at the limit Join Date: Nov 2010
^^ The BMR braces are awesome! Feel free to Call, PM or email me with questions.
Best regards, Tyler 888-308-6007 |
01-31-2013, 01:49 PM | #12 |
Russ
I bought a BMR strut brace and had it shipped to me unfinished. I had it chromed by a local chroming company. I like the way it turned out.
Russ |
01-31-2013, 02:29 PM | #13 |
Drives: 2010 2SS/RS L99 IOM Join Date: Jan 2013
01-31-2013, 02:59 PM | #14 |
You have to drop the struts and drill 4 holes on top of the tower and bolt it on.
