Old 03-19-2020, 07:55 PM   #1
Nubsnapper
SITH SS
Nubsnapper's Avatar
Drives: 2017 Camaro 2SS Convertible
Convertible Sway Bars
Every aftermarket sway bar I can find says coupe only. What exactly is different about the convertible sway bar and does anyone make them for the vert?
2.9L Whipple, Rotofab, TSP 2" LT's, Cat deletes, SMG flex kit, Snow meth system and Calibrated by Karger. Custom black stainless dress up by American Car Craft.
Nubsnapper is offline   Reply With Quote
Old 03-19-2020, 08:06 PM   #2
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
You can upgrade to the OEM ZL1 Vert's sways (FE4)
driven2exceSS is offline   Reply With Quote
Old 03-17-2023, 01:10 PM   #3
bereic
bereic's Avatar
Drives: Camaro SS 2018 Convertible
Did you try the ones from 1LE or ZL1? is it worth?
bereic is online now   Reply With Quote
Old 03-19-2023, 05:32 AM   #4
rcinsolo
Drives: 2023 Camaro 1SS 6 speed convertible
Are the chevy performance better than the ones that come factory or did I get a non listed accessory?
rcinsolo is offline   Reply With Quote
Old 03-20-2023, 09:10 PM   #5
Roddrz
Roddrz's Avatar
Drives: 2022 Camaro V6 2LT Convertible
The rear sway bar is bent in the middle to go around the convertible's bracing.
On the coupe, the bar is straight.
I ordered the ZL1 FE4 Convertible Rear Sway Bar from GM - GM #84118919.
This is the part they sent and it is too thin. The part is the same part on my 2LT FE2 suspension.
- Diameter - 0.78 inch
- Circumference - 2.48 inch
Can you check the Diameter or Circumference on your SS convertible's rear sway bar?
I was hoping the diameter for the upgrade SS or ZL1 FE4 is 0.98 inch.
Roddrz is offline   Reply With Quote
Old 12-27-2023, 07:15 PM   #6
bereic
bereic's Avatar
Any news here in regards of the ZL1 sway bar? Is it worth it on the SS?
